Hi everyone,
I’ve read too many posts by Bonzo and decided to move away from the traditional box speakers
Unfortunately, I don’t have a dedicated room. The system is in my living room. The room is about 35 m², but it is combined with kitchen, so the listening area is just about 20 m². There is no wall on the right side and a big window on the left side. I sit on a sofa which is next to the back wall, so there is no space behind. As you can see in the picture, the front wall is not straight and there is a built in cupboard on the right side of the wall. The distance to the current speakers (Sashas) is 2.85 meters, 2.60 between the speakers.
So far, I’ve narrowed my choice to Avantgarde Uno SD and Diesis Caput Mundi. But maybe Caput Mundi would be too much of a speaker for my room, and I should consider Aura? I have many questions and concerns, but hopefully I am moving in the right direction.
My main concern about Avantgarde is the complexity of the setup. My understanding is they are much more demanding to correct setup compared to Diesis. In case of Diesis, I am concerned about my listening area size and the base extension compared to what I’m used to (Sashas) and I don’t have any room for subs.
Any thoughts?
Thanks in advance,
Aziz
Any thoughts?
Thanks in advance,
Aziz
