Wadax Studio Player Review
I don't recall every audio company showing their products undressed for the world to see over the last 50 plus years. On the Wadaxwebsite there are diagrams and details of what the inside contains and even a "see through" picture.
I'm truly not understanding what else you want and why.
Does every other digital company show their naked guts? I'm asking for a friend since I personally don't find this important.
BTW I still have KINGREX blocked and I still don't like him :)
Oh, 99% of other manufacturers make no secret of it; if something's revolutionary, the circuit is patented anyway. Diagrams aren't interesting; they don't look any different from any other; they're just like the rest. I'm naturally curious about how it works, what components they use, and what circuitry they have. Although that's difficult these days, since everyone uses SMD components, it was and is easier with tubes. Don't worry, I usually find everything online, or a friend who buys one of these devices can.
Reactions: Klonk
99 percent WOW can you show me proof of that? I would like to see a complete list of all including the pictures
At least it would be interesting what streaming platform the WSP uses. There are not so much on the market, most manufacturers use ConversDigital or StreamUnlimited. My guess is ConversDigital :cool:
I would bet on streamunlimited with software sdk you can integrate all music services of the world and end devices with custommade programming (no matter connection usb, wifi bluetooth etc..) I will look out if stream 1955 module can be seen in a photo;)
P.S Metronome use it too
TMZ reports, but could not be certain, that the Wadax Studio Player was spotted at the Bezos/Sanchez event over the weekend.
These reports however are inconclusive. They had sent their leading "tube detector"
Reactions: mxk116
I’ll have a chance to audition Studio Player in my room as a possible replacement to my Aurender / Lampi combo. I wonder if there is any way to play my local files, which are stored on the Aurender internal drive? I also have some music stored on Synology NAS, but I am not sure how to access it from Wadax. Another question is about optimal impedance setting for CH L1.
Thanks in advance,
Aziz
Thanks in advance,
Aziz
yes. the Wadax Studio Player has Ethernet and is UPnP compliant and can act as a UPnP Renderer to read remote files on your network. not sure whether your Aurender can be that source device. but transferring those files to an appropriate NAS ought not to be too difficult.
as i recall my Wadax Reference Dac is set at '0' impendence and ''1v' output. but it's been over 3 years since i set it. i think i did some listening between a few choices and that is where i ended up. with the Studio Dac there is a volume attenuation capability so that might affect which is best.....even though you are not using it.
Reactions: abeidrov
Thanks in advance,
Aziz
you will need either Roon, or Jplay to access the files on your network. The Studio Player works with both of these .
You should try adjusting the impedance to match your system. I think that you may find somewhere in the 8.3 area might , and I emphasis might since its your system be about right. The output voltage is either 1, 2 or 4 volt. I also suggest that you try them to see which again works with your system.
FYI I use different output settings in my two WADAX systems since they have different Preamps.
I suggest you give Qobuz connect a spin since it is quite good.
Reactions: abeidrov
I’ll definitely use Qobuz connect, and it hopefully should be enough to hear a difference between Lampi/Aurender and Wadax. The combination of Gryphon and WA gives already a very dynamic presentation, so most likely I’ll use 1 or 2 output voltage setting and higher than a 0 impedance value.
Reactions: mxk116
Plenty of silicone seen in Venice that weekend.
Not sure that's great for audio.
Reactions: Mike Lavigne
Try the different settings once you get the system going and you will be able to make some changes for the improvement of SQ
Have fun!
Reactions: abeidrov
Thanks in advance,
Aziz
I have a Studio Player incoming. I currently use an Aurender streamer (N20) with local files on a 4TB SSD. DAC is the Esoteric K01XD.
I made an abortive attempt trying JPlay with my current digital setup. Seems JPlay is not compatible with Aurender. Haha, serves me right for trying to get a head start.
I contacted JPlay to ask if there is an incompatibility with JPlay and Aurender. Marcin (JPlay) replied that "Aurender does not support UPnP and therefore can't work with JPLAY app." According to Marcin, JPlay is compatible with the Wadax in general including the Studio Player.
Confirms what others have mentioned. In my rig streaming using Qobuz Connect is superior to using the Aurender Conductor4 app.
Reactions: Elliot G.
Am I the only one, who prefers the 180 phase setting on WSP?
I’ve read somewhere that Wadax is working on a new Studio DAC / Streamer device without CD playback. Is it true or just a rumour?
I have recently installed a Wadax Studio to my system. I love the tone and musicality of it. The other parts of my system are CH Precision L1 + X1 +M1.1. My speakers are Wilson Alexx’s. Can I ask for recommended settings for Voltage and Impedance. They are currently set at 4V and 0 ohm. Looking for recommendations. Thanks!
Reactions: Scott W
