I never remember any ducking on my part? Everything from about 20 mins on should be of interest but here are some relevant excerpts:I did look at that video, but I'm not willing to sit through more than an hour just to learn that you likely quoted him out of context, or find out how he's mistaken. If you tell me specifically what part to watch I'll gladly do so. YouTube makes it easy to skip around. I seem to recall asking you for the time many pages back and you ducked that.
At 23:45 "It is very hard for us engineers who are used to looking at FFTs and seeing 150Db of SNR, it is actually very hard to believe, to accept that people can hear something that none of instrumentation an measure............ the one that's not so good is the sigma delta modulator despite having so much better technical specs"
At 26:00 "Dustin Forman, who is one of my best engineers, has trained himself to listen for what the audiophiles listen to."
At 27:00 "Even though you can show, Frank Sinatra's New York, New York, has a fairly horrible SNR, it still exposes errors in a sigma delta modulator that is a hundred times better than the original recording & it's because the human ear can detect signals well below the noise level present"
Ok, so I hear you say that this is all anecdotal & furthermore it's plain marketing. So skip to the measurements section from about 34:00 on. Just to help the slides are to be found here http://www.esstech.com/pdf/noise-shaping-sigma-delta.pdf
Yep & a similar accusation could be levelled at you as you sell room treatment products! Your line of all DACs, amps sound the same could be considered to neatly dovetail into your focus on speakers & room treatment. So should this same cynicism be levelled at your statements?Said the guy who sells expensive converters.
Sorry, here is the correct one, I hope http://arxiv.org/pdf/1208.4611.pdfYour link is broken but I figured it out anyway.
Yes, maybe you don't understand what you are saying? The paper says that hearing can simultaneously evaluate frequency & phase to a more precise & deeper level than the mathematics allows & also beats any existing current measurement instrument, in this regard! Is this not what you understood from reading it? Take either one in isolation, frequency or phase, as you will no doubt want to do & measurements can beat hearing but only in isolation. We listen to sound envelopes & not to frequency or phase in isolation! I don't know what you don't understand about your quote "FFT uncertainty bounds" but if you say what it is that you are uncertain of maybe I or others can help?Regardless, that paper says no such thing. It compares "FFT uncertainty bounds," not what is possible to measure. You should run for president of the US.
--Ethan
