Best Pancake Recipe
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
Pancakes are the simplest of Sunday breakfasts in the Koh family - just pancakes lathered in maple syrup and a cup of tea. Simple is easy. I'm known for saying "as simple as possible, but no simpler".
However, for the simplest of breakfast - you need the best of pancakes. No store-bought mix is going to even remotely approach "Daddy's Pancakes" for my kids.
I start off with King Arthur Flour (never bleached, never bromated) and Grace Harbor milk (local, family-owned, pastured cows).
Here's the way to make light, fluffy pancakes with a depth of texture and flavor that you'll never forget. Crispy on the outside, light and moist on the inside.
In a large mixing bowl, sift together 2 cups of all-purpose flour, one teaspoon of baking POWDER and half teaspoon of baking SODA.. Mix in a tablespoon of sugar and a half teaspoon of fine sea salt (or I like to use freshly ground Himalayan pink salt).
You'll need two more mixing bowls - one medium and another large. You'll also need 4 tablespoons of melted butter - use European butter as American butter has too much water and not enough flavor. I use Kerrygold, but others will work just as well. To melt the butter, I put it into a small glass bowl and microwave it for 2 minutes at low power.
Carefully crack three large eggs one at a time. Separate the whites into the medium bowl and the yolks into the large bowl. With a hand mixer, whip the egg whites in the medium bowl until they form stiff peaks (sort of like if you were going to make meringue).
In the large bowl (with the three egg yolks), pour in two cups of cultured buttermilk, half a cup of yogurt and a splash of whole milk. Use the hand mixer again and mix until the dairy and milk is uniform. While mixing, slowly pour in the melted butter.
Next step is important. FOLD in the whipped egg-white into the milk/egg mixture using a rubber (most likely silicone these days!!). It should still be lumpy when you're done. Pour the dry flour into the mix and continue to fold the mixture together. It should end up lumpy, but fairly consistent.
Optional, in a mortar and pestle, crack a handful of roasted macadamia nuts. You don't want to use a food processor as you want some larger pieces, other smaller pieces, and the mortar and pestle will release the oils better for more flavour....... fold this into the mixture too for an even lumpier batter :)
Fry over medium heat (on the low side of medium) in a non-stick pan until the pancakes bubble.
Flip once only! For crispy on the outside and fluffy on the inside, I use a carbon-steel frying pan. A teflon non-stick will work, but the pancakes will be less crispy on the outside. You'll have to adjust the heat depending on your pan and stove top to make sure that the pancake doesn't burn by the time it has to be flipped. Deep brown is OK as the sugars in the mixture is going to caramelize.
Enjoy - with a generous helping of good maple syrup. The recipe makes about twice this amount. My kids started eating while I was cooking up the batch......
They are wonderful pancakes.
Not that I can eat them anymore. :p (T2 Diabetic)
I saw it on your FB page Gary but the photos here do the recipe more justice
Reactions: Nicholas17Dominic
es347
35
970
Midwest fly over state..
..at the risk of being laughed off the forum we've found that the Cracker Barrel pancake mix is right up there. Great taste of course but a texture that is hard to describe and of course topped with real maple syrup...no Mrs Butterworths thank you..
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Yes - I agree. FB doesn't do this justice, WBF is also much easier to bookmark as I put my best recipes in here so as to be able to find them if I want to do it again.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,474
994
1,290
Same here, Steve. They looked good then and they look great now. Thanks for sharing, Gary. The wife and my son love making pancakes and we always do it by scratch, trying different recipes along the way. In fact, this Easter, we had fun making bunny shaped pancakes using blueberries and bananas for the eyes and mouths. We will definitely try your recipe.
On a different note but not completely off topic, I see that you mentioned using a carbon steel pan. I have been on this Earth for 45 years and I have heard of all kinds of pans but it wasn't up until about a month or two ago that I heard about carbon steel. From what I understand, there are many benefits......kind of like cooking in a cast iron pan but with the benefits of a "non-stick" pan, if you will. Would you agree?
Also, I notice that your carbon steel pan has no rivets connecting the handle. That is the bomb! If you don't mind me asking and if you happen to remember......where did you source that pan?
Tom
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Carbon steel pans are the bomb! I've used a carbon steel Chinese wok for many years, and it was only recently that I discovered that you can also get frying pans in carbon steel.
When cooking steak and other meats, the maillard reaction is as good if not better than cast iron. And, a well-seasoned carbon steel pan is more non-stick than teflon, without the down-sides. I can fry eggs without a puddle of oil - just wipe the pan with an oily rag (never wash the pan with soap). Unfortunately, the pan will pick up the taste/smell of what you cook, so I have different pans for fish and pancake/eggs.
The pan I use is a Matfer Bourgeat - I got it at a restaurant supplier, but you can get them from Amazon. You'll be amazed at the price.
http://www.amazon.com/Matfer-Bourgeat-062001-Frying-8-Inch/dp/B00077H56I
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Brand??? The good ones are hand-hammered in China. What constitutes a good wok is opposite to what you'd expect. It should be thin so as to transmit the heat really fast. Viet Wah in the International District or 99 Ranch in Lynwood or Renton sell them. Mine isn't a traditional wok (it's too thick), but I've been using it for over 30 years so I just haven't had the desire to change.
Use something like this - with a handle on both sides.
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
Thanks Gary. I found one and it was thin and I thought that was bad! Will drop by 99 Ranch and pick one up there. I had forgotten about that market :).
I need to have you and your family over to teach me how to cook chinese! :)
Ronm1
1,745
4
wtOMitMutb NH
From scratch can be great, but what works surprisingly well is a tweak(right up our alley ) to a basic bisquick recipe. Add some acid oj, lemon juice and baking powder let it work a few mins. Crisp well with the right pan and fluffs up well too.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
And with great pancakes (French toasts too) comes great power and responsibility. :b
Nothing better than arroser le tout avec du bon sirop d'érable. ...And with fresh strawberries from the fields across the valley.
______
Mobiusman
704
560
1,655
Jersey Shore- waterside
I start off with King Arthur Flour (never bleached, never bromated) and Grace Harbor milk (local, family-owned, pastured cows).Gary, absolutely wonderful post and incredible pictures. I have thinking about making some from scratch for the past several weeks so that I can use the amazing syrup in my frig and you have just pushed me over the line.
Great post and pictures Gary. You read my mind for the past several weeks craving pancakes so i can use the wonderful syrup in my fridge. I will try your recipe.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I haven't made Pancakes in years. I do make Crepes several times a month though.
beaur
Fleetwood Sound
Oct 12, 2011
460
166
950
60
Brooklyn
To those that may be lactose intolerant and for people that don't want dairy; Replace the milk with the same volume of seltzer. Pancakes actually get fluffier.
bonzo75
22,588
13,619
2,710
London
My gf makes protein pancakes with protein powder in the batter
