I'll state that I'm not personally a fan, but that doesn't mean they can't be done right.
What are you talking about?
If they produce poor sound why would I think otherwise? I haven't personally heard one that I'd take home.
Please stop trying to twist obvious implied meaning into annoying catch 22's. If you have it out for me try a PM, thanks.
Removing noise and having clean power is not a problem. How it's done can create as many problems as it fixes, that's overly common.
Non-understandings of a lot of factors involved with such devices, including passive filters, cause an awful lot of issues. They give other similar but correctly designed things a bad name.
Providing that the isolation transformer have sufficient capacity, preventing it from going into saturation.Isolation transformers don't produce poor sound their function is to isolate a component from the AC source and suppress electrical noise that's all, its effect of this isolated and cleaned electricity on the sound which is the problem.
david
BFlowers,
Congrats!! I did not do isolated transformer in our home either. Just dedicated lines and backup power. (...)
LLoyd,
Mains secondary distribution in the US has different characteristics than in Europe -e.g., as they have lower voltage, step down transformers are typically placed closer to to users.
Unless we consider all the functions of the mains (supplying energy and noise, but also operating as an electrical noise sink and/or distributor for your own equipment and appliances) we can not understand why the advice on this subject can not be generalized. It will always depend on location and equipment. People are only reporting their own experience - we can learn from them it as it opens our mind for possible problems and solutions, but there is no universal recipe.
Electrical engineers consider electric power quality mainly in terms of frequency and voltage stability, DC residual, mains voltage flicker, harmonic distortion and transients. You can have a power line that fulfills the specifications in all these factors and still is not perfect in terms of audiophile requirements!
Each of my components is connected to an isolation transformer with RC . It result in a very big improvment in sound and no limitation in power ,and I have 2 classe bridged amps.
LLoyd,
What is the total length of power cable (in-wall wire plus power cord) between the isolation transformer and your amplifiers?
Each individual auto transformer is set beside the component.
Sorry it's an isolation transformer.Gilles13,
Probably it is just a translation matter, but an autotransformer is not an isolation transformer and does not isolate the equipment. They are usually used to step the mains voltage.
