Hi guys,
I'm a CH D1+C1 user and looking for amps to drive my rockport Avior. The room is relatively small about 280 sqf, do you think L1+A1stereo is enough or L1+M1 is significantly better? In what way?
Thanks,
Michael
Kerem ( Absolare) have used his Integrated amplifier on shows, f ex in Munich with Rockport. You cannot go wrong with that amp, it is fantastic. I have the C1, D1 and X1 with this amp in the Signature edition.
Good Luck.
JP
Hi guys,
Thanks,
Michael
Michael, My experiences with CH A1 and M1 suggest that you will be fine with a stereo A1 in your 280 sqf room with Rockport Avoir. My room is 350 sqf. I started with a D1/C1/A1 combination driving Wilson Alexia. No problems at all. The A1 provided plenty of power. When I switched to Zellaton Stage speakers, I traded up to the M1. As Gian60 points out, there are some differences in dynamics and scale with the M1. Both are wonderful amplifiers. My experiences suggest that you would be better served by buying an A1 and using the difference in costs between the A1 and M1 to add an L1 or X1 to your system. The C1 has an excellent pre-amp circuit in it but the L1 opens up the presentation considerably. Adding X1s to your system will lower noise floor, add dynamics and punch. Good luck.
Good Luck.
JP
Also you can buy A1 stereo and in future another A1 to use in mono
I never tried A1 mono vs M1 stereo
I compare A1 stereo vs A1 mono and mono is better in weight,dynamic and fast,and the incredible thing is that you can biamp in passive way.
For example if your speaker can biamp or biwiring you can use A1 mono to use one channel for low and other channel for mid/high and you can select the gain of the amp for every channel,so if the sound is little dark you can increase the gain of mid/high
So i think A1 mono is better of M1 stereo
Hi JP, your setup looks awesome! I've heard lot good things about Absolare but it's difficult to get an audition here in HK.
I went to the showroom to audition CH A1 stereo powering Wilson benesh speakers 2 days ago, front end is CH D1+C1+L1, the sound is smooth, crystal clear on the top end but a bit lean and cold in tone color. Not to my liking very much I'd say. Hence I decided to try something else as well, tried soulution, nagra, so far I'm sold to Nagra. The classic amps in bridge mode as mono powering the same speakers, the sound was warm, transparent and somehow much more engaging than the A1, very seductive.
Nagra is making some great sounds with their current line up !
