Does anyone understand why Wilson speakers sound best with BIG POWER? Anyone understand the designs of most models, and why is Alexandria different?
P.S. Simple question, guys. Enough of the BS, please stay on topic.
I totally disagree
I've driven Wilson's over the years from Krell Mcx 750 then ARC ref 600 Mk lll, then Lamm ML 2.1 and my present Lamm ML 3 with 32 wpc
Sound was different with each however I'm done with electronics as my Lamm Signatures are lifers. My speakers BTW are 95 DB efficient. Virtually anything can drive them
Here’s a thought.( from a marketing perspective)...the typical buyer for Wilson’s may be put off when told that the best amp for them, needs to only put out 15-30 Watts. Probably better to try and sell a mega power amp ( doesn’t it sound a lot better if the amp can put out 500 Watts/ ch!)...naturally at a mega price.![]()
but I have to wonder if you've got 'near limitless current/over-spec'd' 50-watt amp if you'd care with a pair of Alexias or ever miss that extra 700 watts of power given the 'sensitivity' of the Alexia from a decibel standpoint.
Im building such an amp (sort of). It's a single output device (MOSFET Class A) with an operating voltage of 7.75V. But the current capabilitys are greater than 25A. The power supply is massive.... for the prototype it's a lab powersuplly capable of 100A. Im planing on a final powersupply capability of 2000+VA....
Personally, I think there is QUALITY power and there is TONS of power. Both have their benefits...but it is ultimately the balance of these kinds of factors...plus the interaction with the speaker that matters. With respect to the Wilsons, I do think that the big Wilsons are different from their smaller bretheren, though i have not heard the Alexx. The smaller ones do come alive with a far greater amount of limitless power...but i do wonder if you had an insanely spec'd 50 watt amp (ie, Aries Cerat 200kg power supply monster, or Steve's 4-box 32-watt reference Lamm) whether the QUALITY and high current of the lower-wattage amp would still make music with the Alexia.
Ultimately, there are going to be things a Naim Statement 746 watt into 8ohm will do that a lower-watt amp wont, but I have to wonder if you've got 'near limitless current/over-spec'd' 50-watt amp if you'd care with a pair of Alexias or ever miss that extra 700 watts of power given the 'sensitivity' of the Alexia from a decibel standpoint.
Good points. As always, each case is a difference case. IMHO Wilson speakers are not too different from other box speakers, however people have higher expectations from them, and fulfilling them needs quality power as you refer.
It's finished on paper. But there is another finished amp design I wan't to build aswell (Negative Output Impedance Amp).
When I decide I'll let you know.
I'll start ordering the parts before christmas. The build will start around christmas...
It should work. But you don't know anything before you test.
GMFK,
Can we know why do you want to built a design known to be instable and have higher distortion?
20.32W 8Ohms
