Aqua Formula - new upgrade, retrofittable!
Wow, the GG is $20k+ USD. Separate thought but has anyone compared the Lampizator Pacific to MSB or TotalDAC 12?
Has anyone compared Pacific to GG yet? Pacific valves are still restricted, the other valves haven't rolled out, so I will be able to valve tune my GG to beat the Pacific.
My q is not so much whether balanced is better.
I gather the vast majority of, if not all, dacs sound better balanced.
It’s whether single ended is decidedly worse, and loses any performance superiority the dac has.
How much of a SQ discount there is with RCA compared to XLR, I suspect is quite preamp dependent
Our experience with Aqua Formula playing through RCA is very limited. Sorry can not be more helpful
Here is a very nice review of the Formula xHD dac: http://www.hifi-advice.com/blog/review/digital-reviews/spdif-dac-reviews/aqua-formula-xhd-dac/, some comparison to other DACs, USB vs other inputs, XLR vs RCA.
I noticed that Formula has a modular input option. The available options for the Modular Input are AES/EBU, RCA, AT&T ST Glass and Optical TOSlink. The reviewed sample had AT&T ST Glass input. Is this an Ethernet input or something else? What source can be used with this input?
Thanks.
Thanks.
thank you for the review link. the nicely written review mirrors my views on the Formula dac as a top performer and clear view on the music. too bad not much on the addition of dsd to the performance.
My thoughts too. I'll probably do it in a few months but would like to know how natively DSD sounds.
Does anyone know how the Formula decodes DSD since it is a ladder DAC? Does it convert DSD to PCM internally or does it actually have some sort of on board DSD decoder?
It is my understanding that DSD is converted to PCM internally.
Can someone with the xHD upgrade + HQPlayer share what settings you have found to work well with the Formula xHD?
I emailed Aqua and they confirmed that the Formula does convert DSD to PCM internally. They tried different solutions for DSD playback and determined that the best sounding solution was via DSD to PCM conversion.
I thought the upgrade rectified that and does DSD native?
I am now listening to an Aqua Formula xHD. The unit is brand new and probably needs another week of burn in. But so far, I am quite pleased with what I am hearing. Despite the internal conversion of DSD to PCM, DSD playback is comparable to my Lampi, and PCM is simply stunning.
https://youtu.be/ySXOhTEbVKw
Awesome! BTW - who is playing in the video?
I really enjoyed the sound of Formula till I put my Lampi back... Now I am at a complete loss, as I no longer hear the difference, that I think I heard before. Maybe I imagined it:( Maybe it’s a burn in issue.
Anyway, I will give the Formula another couple of days but I doubt that there will be any dramatic changes.
What tubes do you use in your GG?
I wish it was a GG;) It’s a Level 4 dac.
For what it's worth it took a long time for my Aqua Formula to break in. Aqua recommends 200 hours but I found it took closer to 300 for it to settle down.
Oh geez. You should buy a used GG then. It will be less than a new Formula retail. Ask Lykasz...I am sure he has trade ins for PAC buyers.
I had L2 and then L4 and the B7 and then GG. GG is far far beyond L4. I know for a fact.
If I don’t go for the Formula, I am thinking about a new GG2. It’s just more expensive and lots of confusing options to choose from. But that’s a topic for another thread.
