Granite base
Hi-FiGuy
2,269
797
450
Enlighten me if you will,
First time I saw granite blocks under some amplifier's I thought cool!
They actually were blems from a tombstone maker.
Then I got to thinking, this to me, seems more or less a direct couple to the floor and would offer no sound benefit.
What say you?
Granite is ok if it weighs enough, but few if anyone really gets to that level with it. It is very solid and tends to transmit some, so it need constrained layers or to weigh like 400lbs+.
Granite is an excellent material for kitchens and bathrooms. Sadly, not so much for audio, at least not IME. Nor is marble. From all the stones i have tried slate sucked the least, but still, best avoided. TBH only tried South African slate, so there is a bit of a lingering doubt: perhaps the Italian slate is the musical slate :)
All these stone plinths...i just don't get it.
Slate does have its own colloration so needs to be properly damped, best sandwitching with metals.
Cheers,
Both HRS and Boulder incorporate granite into their isolation bases (HRS M3X shelf and Boulder 3060 and 3050 amps). However, both also use other materials in those stands...not just a standalone slab of granite. (In fact, am a big fan of HRS M3X isolation shelves and use them now.) Granite used by itself as a base...I too am not convinced.
What say you?
Very negative experience with granite under audio equipment including speakers. Hard, thin sound like you get from some footers.
david
Reactions: engadin
'had a discussion with HRS about Granite and Slate. Slate might have a better inner damping, but every part is unique , so very difficult to guess the particular damping effect. Granate is more easy, significant resonances, but only depending on the size, so easy to control. On HRS M3x this resonances are damped. Granite can transfer mechanical energy very fast, so this is the main reason granite is used on M3x, than this mechanical energy gets "killed"
They do not recommend slate or granite as stand alone base.
Great insight...thanks.
I use granite slabs with compression springs under 2 of my turntables. It works very well and easily beats the SRA and Symposium platforms that sit on the floor in my music room. Sounds 95% of the Minus K platform @ 1/20th the cost.
Sounds ingenious. What kind of compression springs did you use? How did you affix the whole thing together?
Lloyd. nothing special. piece of granite with compression springs underneath with "golden book" cardboard pages protecting the stand. see old photo below. I use 4 springs now as its supposedly better to have the total weight closer to the maximum weight allowance of the springs and does sound better.
Same principle that Townsend now use on their Seismic isolation products.
http://www.townshendaudio.com/hi-fi...t-vibration-isolation/seismic-isolation-pods/
Nice!!! Very interesting about max'ing out the spring loading to improve sound performance as well. thanks!
Granite slab floating in a tank of mercury
