Munich High-End 2018 Ron Report: D'Agostino Master Audio Systems Relentless Amplifier
19,630
17,606
3,530
It looks big and pretty and very well-machined in person!
Frequency Response 20 Hz to 20 kHz, ±0 dB
<0.1 Hz to 100 kHz +0/-3 dB
Signal-to-Noise Ratio >113 dB, wideband, unweighted, ref. to full power output
Gain 26 dB
Total Harmonic Distortion <0.007% at 1 kHz, at 1,500 W, 8?
Input Impedance 100 k?
Output Power 1,500 W RMS at 8?
3,000 W RMS at 4?
6,000 W RMS at 2?
Output Voltage 320 V peak-to-peak
113 V RMS
Output Current 400 A peak
Slew Rate 100 V/?s
Output Impedance <0.03?, 20 Hz to 20 kHz
Damping Factor >267, 20 Hz to 20 kHz, ref. to 8 W
Power Consumption Standby: 40 W
Idle: 400 W
Maximum: 10 kW
Inputs 1 balanced via XLR connector
Outputs 1 pair binding posts
Dimensions 22.5 x 11.5 x 32.5 in (whd)
57.2 x 28.0 x 82.6 cm (whd)
Weight 485lb/220Kg
Did they post an MSRP of that amp?
I believe they modify the discs in your back from healthy to slipped/prolapsed upon trying to lift them
Ron! We need you or Tinka to stand next to it for scale.
Saw a picture with Dan the man in the background. All I can say is, if you can afford this you can surely afford the army of power lifters AND pallet truck you're going to need to move it. It is HUGE.
