Few DIY projects
I previously make the last layer-10 mm MDF / to get a sandwich construction / on the front panel and the bottom and of the top.
For the side panels, last layer is 1 x 4 mm plywood and everything is re ady for the measurements.
And a risky picture (everything is supported by gravity), how look for compared to the front speakers, are not on one line, but I rely on your imagination.
Several steps to the moment with measurements ...
Clarification, this is a polyurethane primer, I will be make veneer on the on cabinet's with "Birds of Maple".
The first home tests are good.
My current surround speakers of " Technics" CA-10 with a good sound from 1997, they are sadly retreated himself ...
After the measurements, this is are Technical data:
Frequence Range; 33-25000 Hz
Long term Max Power; 200 W
Crossover Frequency; 2800 Hz
Impedance; 4 Ohms
Sensitivity; 90 db SPL
Cabinet Volume; 31 L
Gross weight / without stand /; 27kg.
This is the project of the rear speakers, will finish it with "Bird's eye view". There will be a sequel ...sometime..
Joro Raitchev
Sofia- Bulgaria
A very underestimated moment - work with multilayer MDF!
There's still a lot of work on the stands.
I show you a few pictures of the front speaker bases, the rear speaker stands will look like the same;Always been a problem with the MDF, especially when we have a multilayer construction. Over time, individual parts are beginning to show up - all of this is the result of improper processing. Soon I will show you how to deal with this problem.
These days I remembered that I did not discuss my veneering technique with natural veneer for cabinets with a polyurethane varnish base. Like this pozicion-1
how i maked and finish in pozicion- 2?
Your woodworking is awesome! Thanks for posting! :)
I've only done simple 2-D veneering, that looks like a challenge...
Thank you !
I don't know to exist 3D veneer - I'm kidding!
Showcase your work, if you wish, I can give you useful information.
Joro
I show you a German site, that offers such "DIY loudspeakers -cabinet " and please, for your attention, they want money for such a product;
@ jojoraitchef.
I like (admire) your wood-skills & perseverance & multidisciplinaire tech. in the (home) field (even your audio scène) .....
Congrats for your project.
Karel
(one note: be careful with issues difference dilatation coefficients & home temp/Hr...)
@ jojoraitchef.
Karel
Thanks for your good evaluation!
Joro
Not everything is as easy as it seems, the problem with the seasonal movement of MDF material is not to be underestimated! Typically, problems with the multi-layered construction of MDF details occur after several seasons, I'll show you how I handle this task: 6.jpg
On the first photo, we can see the hidden problem that will appear in a few years is very well.
I show my way of dealing with this task;
