How do you clean your stylus?
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
Some tools of the trade ...
awsmone
1,616
514
435
Canberra Australia
It’s interesting the cleaned ones tip is black, could just be shadowing ?
I was wondering could a ultrasonic stylus cleaner damage the stylus mount or the suspension of the cantilever
NorthStar
24,305
1,323
435
I too thought it was the light's angle creating the shadow, but from searching further it wasn't.
Some stylus are completely transparent, others are black, some have a different material termination. ...We have diamonds, sapphires, etc.
4,704
Does anyone use something like this? It is basically an ultrasonic cleaner which is used with a drop of cleaning fluid.
I used it quit a bit back in the day without problems until I read that the fluid could damage the cantilever. I've since
used the Onzow - again without problem. Mine is sort of filthy but I just learned that you can rinse the thing with water
and reuse it. Good to know.
I also own one similar - that I often use, but dry, without any cleaning fluid. Although people often call it ultrasonic, as far as I remember the frequency of operation is around a few hundred Hz.
Reactions: tima
4,704
Another good question
Although there is a dogma that the vinyl melts and then freezes as it travels thru the groove, and this is often repeated, I have been unable to find a study that actually demonstrates this , if others have found a study rather than a quote please forward to me
I was able to find evidence that stylus buries itself more into a concave modulation than a convex
There appears some controversy that the stylus produces adequate heat to melt it in the time of contact
I thought this discussion on cutting vinyl with heating the stylus might be of interest
It would appear that heating of itself might not be an issue with the vinyl, but more the stylus
Stylus heating
Please see: https://www.vinylengine.com/turntable_forum/viewtopic.php?t=27421 . The most complete thread I have ever read about this subject.
Reactions: tima
Folsom
6,030
1,503
550
Eastern WA
Ok so I grabbed a Magic Eraser pack from Ace... This is now my go-to without a doubt. All I did was dip the needle into it several times and it was super clean. It's WAY better than the ZeroDust/SolidState type stuff. I don't think there's any need to brush it. Just a few dips and it's golden. Everything else seems silly at this point.
NorthStar
24,305
1,323
435
I also have this exact same HyperBRUSH ... the replacement/alternative to Allsop's Orbitrac 2
https://www.analogplanet.com/content/orbitrac™-replacement
"TRACKMATE's patented HyperBRUSH technology contains three different types of fibres. 1. The first row of fibres is designed to remove the surface dust. 2. The second row of micro thin fibres dive into each groove to dissolve, absorb, and remove oils and debris. 3. The third row of conductive black fibres removes static electricity. A remarkable stylus brush surrounds and cleans the stylus and lower cantilever."
I does the job for quick cleaning your records and removing static, and the stylus cleaning pad is good too.The other smoother felt pad that Michael doesn't know what it's for (if you are reading this Mikey ...), is simply to pass over the stylus pad to remove the debris from it.
The other link that Michael is referring to is included in his short review.
_____
Bonus: Allsop Orbitrac 3 Pro
And: http://www.soundstage.com/upton05.htm
ack
May 6, 2010
6,774
1,198
580
Boston, MA
I will try it as well today. If Peter is using it too, that says something.
bazelio
2,494
1,748
345
California
The ST-50 is nice after a day of use:
(1) The cantiver doesn't disappear into the goo as with Onzow. The stylus sinks in and just a bit of the cantilever. The cart body can't touch the goo.
(2) Under 10x mag, the ST-50 looks to be doing a better job than Onzow. I have a USB microscope that I've not yet used for closer inspection.
I'm going to get the Magic Eraser next. A few dips into the ME followed by a couple "clean up" dips in ST-50 to remove particulates sounds like a winning combo.
Props to @DaveyF for starting the thread. I now think I've somewhat neglected my carts, having only relied on Onzow up until now.
Reactions: DaveyF
DaveyF
6,129
181
458
La Jolla, Calif USA
Thank you Bazelio. I am going to be very interested to see what you think after you have had a chance to look at the stylus under your USB microscope. Also, what your impressions are after trying ME. I'm still very skeptical about ME, has anyone had long term ( more than seven years continuous) experience with this stuff on their best cartridges?
DaveyF
6,129
181
458
La Jolla, Calif USA
No cartridge last seven years without needing retipped.
That's an interesting point. According to some vintage cartridge lovers, that is not correct, they can last indefinitely without a re-tip!;) I would surmise that it would depend on the amount of usage that the cartridge sees on an annual basis. I picked seven years as that certainly would seem to me to be the expected maximum life without a re-tip of an average use cartridge. Perhaps that is too long...so maybe five years?
Folsom
6,030
1,503
550
Eastern WA
Well, dust and crud causes uneven wear... So whatever the ME does it's very insignificant compared to that.
gilles13
114
25
260
south of France
It' depends of cartridge. My mark levinson mlc1 got a few retip and was working fine for31 years, and now I am going to send it for suspension repair.
My zyx airy 3 after 6 years and 1100 hours had suspension down. The English importer GT audio has recognised on pink fish media that generally suspension get off before they need retip.
NorthStar
24,305
1,323
435
How long a stylus can last? How long a cartridge can last? It all depends ...
? https://forum.audiogon.com/discussions/what-is-the-average-lifespan-of-a-phono-cartridge
? https://forums.stevehoffman.tv/threads/how-long-do-a-cartridge-and-stylus-last.6637/
Any other high-end analog audiophile forum website are all in those lines from the two above links; vinyl engine, audio karma, analog addiction, record player, phonograph world, TT nirvana, diamond rings, ...
There are synthetic diamonds and natural genuine diamonds, there are records purchased brand new and second-hand, there are properly set cartridges and improperly ones, ...everything is important and will determine the true lasting of a stylus and of a cartridge.
Always trust your ears first, and when in doubt examine your stylus with a powerful magnifier (30x to 60x). Some people will use one cart and stylus for years, others they change every year ... same with cars...it depends of the road's conditions, the tires, the weather and the money supplies.
Say between anywhere from 500 to 3,000 hours? 2,000 hours seems to be a number that comes back often.
bazelio
2,494
1,748
345
California
What are the telltale signs that a cart is in need of a retip? I've never done one. And I figure that tip wear is sooo gradual that it may be difficult to know when "it's time".
