How do you clean your stylus?
sdcoomber
1
66
I understand that IPA or Methanol will/may do damage to the cantilever mounting. But is there any reason why I cannot suspend a stylus in an ultrasonic cleaner (40Khz) using just distilled water to get some long term crud off?
jfrech
2,157
753
1,160
Austin
What if that water somehow vibrates into the coils? I think the risk here isn't worth it. Plenty of years tested stylus cleaning methods and even some good fluids. I use a Onzo Zerodust and occasionally Lyra Stylus Performance Treatment every 10-15 LPs...the brush that comes with the Lyra SPT works great dry. I use that every LP side or two.
jn229
112
3
925
Southwestern Ontario
Interesting thread. I have used an old dependable brush from an electric razor I bought in the early seventies, a carbon fiber brush from Discwasher (yup I am an old fart), an Ortofon carbon brush, Onzow and Magic Eraser. My hands are not steady therefore I do not like any cleaning method that is free hand. The ME is cut thin, glued to a washer for weight, to hold it steady, set on the platter and the cartridge lowered into it. The ME is my everyday cleaner.
Reading this thread I made another pandemic (boredom) purchase and bought the thin DS Audio ST-50, like the idea of it resting on the platter and the stylus lower in.
DasguteOhr
2,441
2,621
645
Germany
Hello,
for hard dirt tpyewriters cleaner,and daily use dirt erasers work good.
Best Things in Live are cheap..
Cherrs,Stephan
DetroitVinylRob
274
318
280
Metropolitan Detroit area, MI
Kick’in it ol’ school… remember DiscWasher?
Never quit liking this thing. Horsehair brush with a magnifying mirror.
twitch
602
246
1,605
SE Pa
I put it in the dishwasher on the 'gentle setting' ........ :eek:
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
WOW, this is rather disturbing:
16,217
13,692
2,665
Is it too old school to clean the stylus just by gently sweeping the hard bristle brush from back to front? And occasionally a bit of Last Stylus Cleaner?
Does it have to be any more complicated than this?
Reactions: DetroitVinylRob
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
It’s probably an easy task for experienced vinyl die hards like yourself, who have done it for many many years:) But I am afraid to touch my stylus with a brush. It’s much easier to use the DS Audio cleaning pad.
Reactions: Cableman
jfrech
2,157
753
1,160
Austin
I am glad you posted this. Wow. I think I better stop using mine.
mulveling
234
336
168
I'm still skeptical of claims that the stylus goop was caused by the gel pads alone. Look how filthy the pictured cantilevers are, encrusted with particles - it looks more like a case of bad vinyl hygiene, over time, on the user's part. Gel pads alone were never adequate cleaning. They are good as a lazy shortcut to bust fuzz during a listening session. But your main regimen should incorporate other tools, like brushing and ME - these will not allow goop to accumulate, even if it does come from the gel! And you should brush up & down the cantilever and front plate, as well as they stylus. As with teeth, brushing is a must! You can choose ME or stylast (only occasional use) or whatever else to complement it, but brushing should be a core part of your regimen.
Anyways, I use the DS Audio when I'm being lazy during long sessions (used Onzow before that), and I'm not scared off of it, yet.
Reactions: mtemur and abeidrov
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Do you think Flux ultrasonic stylus cleaner can replace a brush and is safe to use?
