>> I notice that this 213cobra has now given up his SETs for the new Druid 6 claiming that SET can't handle bass below 35hz or so. All this tells me is that HIS Audio SETs, which don't have particularly beefy output iron, were not adequate but that some of the newer more massive designs would be just fine with those speakers. In fact, with a few SETs I know I would never, ever consider PP tube amp bass to be superior (its not and is often mushier) and even SS bass is worse (more one note and overdamped).
I have not heard a single PP tube amp that can compete with a good SET in terms of wholistic musical response and even digging into details. I would only consider an OTL as a viable alternative and even then the tonal balance is too "cold" in many cases. Now, an Aries Cerat SET OTL would be something to hear... ...I haven't had the pleasure yet. <<
It's not a matter of the SET amp "can't handle bass below..." The amp "handles" the bass same as it ever did. It's the speaker that is revealing the bass quality limitations of SET which Definition doesn't fall victim to because in that speaker the solid state amp is actually performing the woofer control. Look, no one likes SET more than me. I've been using SET continually for over 20 years. And I did not find the Druid 6 / SET mismatch confined to Audion. Yes, Audion doesn't have massive output iron, but that's one reason it emphases agility and transparency. Most heavy-iron SET implementations also sound *relatively* ponderous compared to an Audion Golden Dream or Black Shadow. If you find fat bottom bass euphonic and you buy Druid 6, knock yourself out! It's no harm to anyone. But I am finding better balance in Single Ended Pentode, Single Ended Tetrode, and Push-Pull Triode thus far. It's an ongoing investigation. The next entrant is Class A push-pull tubes, 25w.
Every topology has its limitations or faults. SET is intrinsically holistic when done well, but there's greater objectivity to be had in equally-well-executed push-pull. The question is how much of that you can get without losing too much of SET integrity and tone. By going outside the cliche push-pull mainstream circa 2019, you can actually walk right on that line.
Phil
Phil
