Your assumption is that all people hear equally well (both literally and in their ability to interpret what they "hear"). I know from experience this is far from true.
I am well aware of horn flaws, having my first pair in my early 20s (A banged up pair of Klipsch La Scallas). I am also well aware of the flaws of the high sensitivity single driver. Coherent or not, the single driver speakers suffer when the music starts to get really complex and/or loud. The only speakers I have heard that can be single driver, fullrange, and stay relatively uncongested when it gets complicated are big full-range electrostats (not ones with separate elements but single panel or multiple panels working fullrange in parallel). Now, if you load one in a proper horn, like Pnoe, then that relieves some issues. Nonetheless, the single drivers are all colored to some degree compared to a conventional low/mid sensitivity speaker. That is not what they are about anyway.
As you get to multi-way speakers it is hard to make it all sing with one voice. A two way or a very well done three-way can still sound completely coherent though. It is not easy nor always achieved. Technically, Zu is an augmented widebander. Not a bad idea...I will do something similar to mine (not Zus, HDTs).
However, I just recently heard a coaxial based speaker call Live Act Audio. They use an 8 inch coax from Radian (yes the same brand as your tweeter in the new Zus) with convention woofers...VERY coherent and seemingly more accurate than most of what i have heard. Dynamikks uss the same approach to good effect as well. Audiophile Bills crazy horns with 115 db are also a coax for a compression driver...I am sure those sound very coherent as well. Just because Phil (213cobra) says everything else is lacking coherence doesn't make it so. He is right than most normal speakers are not terribly coherent and they lack a lot of attributes that make them interesting to listen to.
Rob, the mods to Definitions involve a single Duelunds cap and resistor each to high- and low-pass filters, and Lundahl transformers to Hypex sub amps.Why do you troll through a Zu thread - I for one am fascinated to learn more about SETS & modded Definitions. I am a huge fan of what Dueland caps bring to the table & as an example here is a the crossover (shock horror) for my 2 way "made in the Land Downunder" speakers.
That's the fun of the hobby!Just got an amp and already we're onto the next one![]()
>> I notice that this 213cobra has now given up his SETs for the new Druid 6 claiming that SET can't handle bass below 35hz or so. All this tells me is that HIS Audio SETs, which don't have particularly beefy output iron, were not adequate but that some of the newer more massive designs would be just fine with those speakers. In fact, with a few SETs I know I would never, ever consider PP tube amp bass to be superior (its not and is often mushier) and even SS bass is worse (more one note and overdamped).
I have not heard a single PP tube amp that can compete with a good SET in terms of wholistic musical response and even digging into details. I would only consider an OTL as a viable alternative and even then the tonal balance is too "cold" in many cases. Now, an Aries Cerat SET OTL would be something to hear......I haven't had the pleasure yet. <<
It's not a matter of the SET amp "can't handle bass below..." The amp "handles" the bass same as it ever did. It's the speaker that is revealing the bass quality limitations of SET which Definition doesn't fall victim to because in that speaker the solid state amp is actually performing the woofer control. Look, no one likes SET more than me. I've been using SET continually for over 20 years. And I did not find the Druid 6 / SET mismatch confined to Audion. Yes, Audion doesn't have massive output iron, but that's one reason it emphases agility and transparency. Most heavy-iron SET implementations also sound *relatively* ponderous compared to an Audion Golden Dream or Black Shadow. If you find fat bottom bass euphonic and you buy Druid 6, knock yourself out! It's no harm to anyone. But I am finding better balance in Single Ended Pentode, Single Ended Tetrode, and Push-Pull Triode thus far. It's an ongoing investigation. The next entrant is Class A push-pull tubes, 25w.
Every topology has its limitations or faults. SET is intrinsically holistic when done well, but there's greater objectivity to be had in equally-well-executed push-pull. The question is how much of that you can get without losing too much of SET integrity and tone. By going outside the cliche push-pull mainstream circa 2019, you can actually walk right on that line.
Phil
(...) I'm very familiar with Martin Logan CLX and Soundlab stats. Although they are single driver speakers, they lack Zu's ability to present dynamic transients, shadings, and decay. They just don't have that micro dynamic ebb and flow of music. (If anyone knows why that is please let me know!!!) (...)
Although I have no experience with Zu's I will add that, within their dynamic limitations, Quad ESL63 have better micro detail, dynamic transients, shadings and decay than the Martin Logan CLX or the Soundlab's.
People train to their preference - all you refer are people's specif susceptibility to specific aspects of speaker performance. No one is absolutely right or wrong in this hobby - at best being right means you share the preference of a clear majority - something that does not seem to be true for the horn speakers being addressed, unless we limit to the sample of the audiophile population to horn lovers ...
Hi Microstrip,
Do you have a rationale / reasonable explanation for that?
Thanks
Nice post. I know that many of us are miles apart, physically, but I wish we would at times listen together so we are able to calibrate our tastes and vocabulary, especially on your comments regarding integration...
YG speakers are supposed to have the best integration of all of the box speakers, but they don't have it either...
Other single driver speakers that I have heard like the Polish Cubes and the German Voxativs are excellent in their transparency and tone, but can't rock! ((If anyone knows why Zus rock better , please let me know!!!)
Right on. I think the frustrating thing at times with Brad's posts is he feels everything except SET/horns is wrong and that the rest of our ears are screwed up if we don't like them. And the irony is he's never heard a properly setup Zu system in a home. I just can't fathom why he (and others) can't understand that folks actually prefer SS over tube, or PP over SET, or what not - and its not due to lack of experience.
Audio isn't black or white - and shouldn't be. My thing is let people try on their own and see what they like- not dictate what they "should" like. Its off-putting, not unlike the Harman/measurement crowd discussions from Amir's days on the forum.
as far as Phil's Zu comments vs horns - as long as I've known Phil his #1 priority is coherency. Clearly any horn/cone system isn't going to make him happy - and there is nothing wrong with that. Others have different priorities (me included). He is correct that WAF on horns is poor and the reason they aren't popular in the US - same with panels. Most of the vintage Altecs, JBLs, etc. are going to Asia - not the US. To say there is a renaissance here is misleading. On the modern front, I've sent messages to JBL several times and *can't even get a demo* in SoCal. There isn't a single pair of Cessaros on the west coast either. The US is very much a cone-centric market and Wilson probably outsells the entire European horn market just in the US alone.
Brad, you're a thoughtful guy, but Zus circa 2009 are the Ice Age. You need to hear them circa 2019, starting w Druids 6. A totally different animal.
When I said renaissance I meant worldwide...US is kind of a backwater in this regard. However, if you look at AVshowrooms you will see more and more horn or hybrid systems popping up in rooms at American high end shows. It is also relative...clear horns won't outsell boxes anytime soon if ever. But compared to what was available 20 years ago...it's a bonanza!
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
