Bespoke Audio TVC Passive Preamp - An Unassuming Star
WilsonDaDa
31
39
85
53
Reactions: brencho
Jpspock
137
69
113
58
Very interesting. It seems that this preamp can be associated to a wide range of Amp… Good to know. :cool:
WilsonDaDa
31
39
85
53
This is a new generation of Bryston. It gets enough power and fine sounding.
The main question of passive pre amp is most likely from the gain output of the source. Once the output gain fits the need of the pre amp (the modern dac indeed helps a lot), the strengths of passive pre amp are easily shown up. :):)
WilsonDaDa
31
39
85
53
This special version of Bespoke silver TVC has arrived at the hk dealer last week.
My friend Paul has not picked it up yet so I went for a brief audition yesterday.
Although not burned-in it gave a huge soundstage, much bigger than the demo Bespoke copper version at the dealer showroom.
Great potential!
I guess this may be due to the bigger TVC copper enclosure/cowl of this special version.
Had an audition of this grand and beautiful passive pre amplifier last night. The soundstage is amazingly wide and deep.
Reactions: CKKeung
CKKeung
3,059
3,191
1,410
Hong Kong
My Bespoke Silver preamp is on the road again!
It's because I am sending it back to Harry & Lucy for upgrading to the spec of Ultimate Silver version, similar to the one owned by Matej Isak of monoandstereo.com
This is the photo of such version :
The main difference is the cowls (outermost enclosures of the transformer).
For the usual Besopke models, the transformers are put inside mu metal shields first and then into aluminium alloy outer enclosures.
This is the internal photo of my Bespoke Silver :
On the contrary, the cowls of Ultimate version are made with brass and are of bigger size :
They are also beautifully plated with true gold :
Due to the diff materials and sizes of the Cowls, the Ultimate version gives a significantly more effortless sound and a much bigger 3-dimensional soundstage.
Initially I was uncertain whether the upgrade was feasible or not, but Ben Lau, the HK dealer asked Harry & Lucy at the Munich Show last year and the answer was affirmative.
Therefore I laision and group together several Bespoke owners in HK and send our Bespoke, some copper some silver models to UK for the upgrade.
Will update you on the progress.
bazelio
2,494
1,748
345
California
Hi @CKKeung , so if I understand it, the change from mu metal transformer enclosures to bigger gold plated brass enclosures is supposed to make a significant difference in the sound? One has to wonder if it's not the case that the mu metal enclosures are somehow deficient in the first place. When do you expect it back?
CKKeung
3,059
3,191
1,410
Hong Kong
The size of the transformers and the mu metal shields of the usual models and Ultimate version are the same.
The only diff is the larger gold-plated brass cowl. There is more filling beewax inside them too.
Reactions: Taiko Audio
Taiko Audio
4,297
13,338
1,925
The Netherlands
taikoaudio.com
The mu metal enclosures are still in place but not visible. The stock visible enclosures housing the mu metal encased transformers are made out of aluminium. These outter aluminium enclosures are the ones being replaced with larger brass enclosures (and more beeswax damping).
Reactions: DaveC
Kingsrule
1,441
704
1,430
I wish they included a bigger cabinet with the upgrade. The cowls sticking out of cutouts on the top plate look out of place.....
CKKeung
3,059
3,191
1,410
Hong Kong
I personally like the look of the Ultimate Silver version very much, even though the original top-plate of my Bespoke Silver is gorgeous!
I didn't sent it back with the preamp.
Will keep it as a souvenir.
hifinutt
76
24
73
64
interesting to read this thread , there is extremely little written on UK forums about the bespoke . when harry worked for music first audio i had the mfa baby reference on which the bespoke is based i believe . I had it the same time as an arc ref 5 and it certainly was superb. the ref 5 only just pipped it in terms of realism but at the time it was double the price . wonderful pre amps
i believe they have upgraded the remote on the bespoke which is good , one reason i do not have a passive of this type in my system
CKKeung
3,059
3,191
1,410
Hong Kong
I changed my ref5se, with NOS tungsol, 6h30dr, for the Bespoke. I will never return back
So was my previous ARC 40th Anniv Preamp. Fully NOS tubes-rolled.
But I liked my Bespoke Silver much more.
Reactions: bazelio
JayDee
36
20
73
53
So. Wonder if i can be controversial. I have been using a new Townshend Allegri reference pre amp with Totaldac drivers. I believe that this betters the Bespoke Audio. Reviews are starting to come out from certain quarters. It will be interesting to see if anyone on this forum with a Bespoke ends up agreeing.
bazelio
2,494
1,748
345
California
That's not too controversial. The Townshend uses an AVC, the Bespoke a TVC. They do sound different in general. And then core material, winding material, etc. Both should be good, it's just that price doesn't always dictate preference.
What do you find to be "better" about the Townsend?
Reactions: KeithR
CKKeung
3,059
3,191
1,410
Hong Kong
Agree with Bazelio.
AVC and TVC have basic sonic diff but none is better than the other.
Execution of the manufacturing and the implementation of them make big diff too.
Reactions: bazelio
