Combining Balanced or Isolated With a Regenerator?
Ron2112
9
As a point of reference, my system, all heavily modified:
101 db Horning Agalme Statement
Horning Sati 520b integrated
Horning Sati RIAA
Kodo the Beat
Kuzma 4Point 14"
Lyra Etna sl
All heavily modified, caps, transistors , All silver/cotton Dialectric internal speakers and components as well as speaker cable and IC's .
I've tried some "power conditioners" with negative (choked) results. At which point trying "regeneration" .... It definitely was a major improvement, I was immediatly sold,... My system incl TT uses approx 750w total, given the lower power I found is very susceptible to anomalies in power.
So I've been looking/researching the possibility of improving my power (about the last thing on my list) . My thinking was feed the regenerator either Balanced or Isolated power, I'm kinda struggling with the difference between the two and which if any would be more advantageous.
Also last "renovation" power from the pole is all new incl panel with dedicated 20 amp lines...
In all reality I'm quite happy with my system as it currently is but in typical OCD fashion the possibility of getting better will play on me till I've exhausted all options...
Crom
10
1
133
Hi Ron, I came across this post as I currently have a Purepower+ 2000 and I am looking into the possibility of feeding it balanced power. did you get anywhere with your investigating?
spiritofmusic
14,626
5,435
1,278
E. England
I can only speak totally positively about balanced power, running an 85kg 8kVA Westwick 8K transformer.
Ron2112
9
I did have a Pure Power 1050, it was great but I sold it and have since acquired a PS Audio p15. So far there have been conflicting opinions on whether or not to use Balanced or Isolated power,. . Now that being said my system according to the meter on the P15 only uses 275w. This suprized me as I'd Thought it was more. I've always believed in having "headroom" so to speak hence the move.
Folsom
6,030
1,503
550
Eastern WA
I like the way Torus units operate.
I’m very suspicious of regenerators because their powercord has a massive effect on the sound.
Ron2112
9
I've had a few passive conditioners as well as couple of pure powers and currently p15,,,, What I've found were passive units cleaned up but flattened out the music. But this was only on bigger power systems.. They definitely were better with the amps (4-300w monos) while plugged directly into the wall...
I do believe at least from my experiences that high efficiency (I run100db+/SET) do benefit more from regeneration than big power. Kinda stands to reason as big power typically have stout transformers by comparison...
Seems to me at least that if I resolved the isolation or balanced transformer question it'd most certainly have to be bigger kva as spiritofmusic mentioned.
4,704
BTW, what are opinions of the high-efficiency fans on the Horning Agalme Statement? I listened to it long ago and it sounded terrific on voices.
timztunz
157
104
150
Texas
I can't address this model specifically but can't speak highly enough about my Horning Eufrodite Ellipse III. I'm amazed with every listen. Even more so with a change from custom made 300B monoblocks to a new pair of New Audio Frontiers Ultimate 211 Special Edition monoblocks.
bonzo75
22,650
13,687
2,710
London
Please anyone let me know where I can listen to these. Have tried hard to find someone who owns them
timztunz
157
104
150
Texas
You might try contacting Jeffrey Catalano at High Water Sound in NYC. He's the US distributor for Horning and should know where some are.
Reactions: bonzo75
4,704
Just saw this old pair upside-down today. They are in storage and for sale, but the owner is not wanting to put them in service or demoing them. They are different from the current ones, these ones have two extremely heavy woofers in a transmission line.
It is the pair I have listened many years ago and impressed me a lot.
160 kg, 211 x 103 x ... (h x d x w) , I forgot to take note of the width.
