Very interesting mouth geometry. I'm not familiar with the idea behind it... ??
Is it suppose to have lower power response in the early horizontal energy?
It's losing some volume as the sides have the air moving faster, going straight out. That I assume would make it more narrow going forward.
Who knows, maybe it's just for looks?
Yes, that is the exact one I bought. It is more directional like a classic Tractrix or other exponential horn. The Horns Iwata is actually not a pure Iwata as it is kind of a hybrid Iwata/JMLC concept (this is why it has the strong curl at the end of the mouth). This concept minimizes resonances in the horn.I found this, which includes a horizontal polar map; it's clearly not a constant-directivity horn, which I suppose shouldn't be surprising:
http://horns-diy.pl/wp-content/uploads/2015/07/IWATA-6001.pdf
And on another page, this commentary:
"The Iwata curve minimizes axial mouth diffraction and allows for a much lower crossover point. This horns posses an excellent clarity whatever the size of the room it is used in."
I think "axial mouth diffraction" is more or less what I was trying to say.
This is the same one that was used by Silvercore.
We nicknamed it vulva
http://zero-distortion.org/silvercorewesternelectricshornssets/
I will probably make some comparison videos but don't want to post them on YouTube in order to link them here. I can send them privately to those who are interested.Super cool. You will have to make some videos.
what do you mean by "also send mobile"?I am. But please also send mobile
The other horn, XT1464 from 18 sound, is an elliptical constant directivity design and goes a bit lower.
sonically, they are both pretty compelling at this point. Despite the low price of the XT1464 it is a very advanced horn design...the Iwatas were quite a bit more dear...but also an advanced design.
Yes, it also has little to no “honk”. The constant directivity honestly doesn’t seem to matter much. Imaging is equally as good with both horns."Minimizes resonances in the horn" makes sense! The length of the horn is "fuzzy" so it does not support internal standing waves which can develop between the throat and the mouth and be a source of "horn honk". I bet the Iwata doesn't have any "honk".
That big 18Sound XT1464 may be the best off-the-shelf 1.4" throat horn out there today. For what I want (which includes constant directivity) it is the best I have found, and I'm using it in a prosound project I'm working on.
Don’t use Whatsapp and don’t want to YouTube it.Not only Tascam videos but also cellphone videos. You can whatsapp video directly or YouTube it
What driver will you use for the prosound project?"Minimizes resonances in the horn" makes sense! The length of the horn is "fuzzy" so it does not support internal standing waves which can develop between the throat and the mouth and be a source of "horn honk". I bet the Iwata doesn't have any "honk".
