I don't know about that. Singapore has more cases than us with a smaller population and they are way more humid than us in these months.I have also read that high relative humidity helps to destroy it. The above said the opposite.
I received the following in an email from a trusted friend. I have no further provenance or knowledge of its veracity, but thought it was interesting.
New information coming from Johns Hopkins Hospital.
IMPORTANT INFORMATION ON THE VIRUS FROM JOHNS HOPKINS HOSPITAL.......
The following is from Irene Ken physician, whose daughter is an Asst. Prof in infectious diseases at Johns Hopkins University, quite informative.
* The virus is not a living organism, but a protein molecule (DNA) covered by a protective layer of lipid (fat), which, when absorbed by the cells of the ocular, nasal or buccal mucosa, changes their genetic code (mutation) and converts them into aggressor and multiplier cells.
* Since the virus is not a living organism but a protein molecule, it is not killed, but decays on its own. The disintegration time depends on the temperature, humidity and type of material where it lies.
* The virus is very fragile; the only thing that protects it is a thin outer layer of fat. That is why any soap or detergent is the best remedy, because the foam CUTS the FAT (that is why you have to rub so much: for 20 seconds or more, to make a lot of foam). By dissolving the fat layer, the protein molecule disperses and breaks down on its own.
* HEAT melts fat; this is why it is so good to use water above 25 degrees Celsius for washing hands, clothes and everything. In addition, hot water makes more foam and that makes it even more useful.
* Alcohol or any mixture with alcohol over 65% DISSOLVES ANY FAT, especially the external lipid layer of the virus.
* Any mix with 1 part bleach and 5 parts water directly dissolves the protein, breaks it down from the inside.
* Oxygenated water helps long after soap, alcohol and chlorine, because peroxide dissolves the virus protein, but you have to use it pure and it hurts your skin.
* NO BACTERICIDE OR ANTIBIOTIC SERVES. The virus is not a living organism like bacteria; antibodies cannot kill what is not alive.
* NEVER shake used or unused clothing, sheets or cloth. While it is glued to a porous surface, it is very inert and disintegrates only:
- between 3 hours (fabric and porous),
- 4 hours (copper and wood)
- 24 hours (cardboard),
- 42 hours (metal) and
- 72 hours (plastic).
But if you shake it or use a feather duster, the virus molecules float in the air for up to 3 hours, and can lodge in your nose.
* The virus molecules remain very stable in external cold, or artificial as air conditioners in houses and cars. They also need moisture to stay stable, and especially darkness. Therefore, dehumidified, dry, warm and bright environments will degrade it faster.
* UV LIGHT on any object that may contain it breaks down the virus protein. For example, to disinfect and reuse a mask is perfect. Be careful, it also breaks down collagen (which is protein) in the skin.
* The virus CANNOT go through healthy skin.
* Vinegar is NOT useful because it does not break down the protective layer of fat.
* NO SPIRITS, NOR VODKA, serve. The strongest vodka is 40% alcohol, and you need 65%.
* LISTERINE IF IT SERVES! It is 65% alcohol.
* The more confined the space, the more concentration of the virus there can be. The more open or naturally ventilated, the less.
* You have to wash your hands before and after touching mucosa, food, locks, knobs, switches, remote control, cell phone, watches, computers, desks, TV, etc. And when using the bathroom.
* You have to HUMIDIFY HANDS DRY from so much washing them, because the molecules can hide in the micro cracks. The thicker the moisturizer, the better.
* Also keep your NAILS SHORT so that the virus does not hide there.
-JOHNS HOPKINS HOSPITAL
Over the past week there’s been a bunch of similar emails circulating and they all seem to have a niece or daughter at Hopkins but never a son or nephew, wonder why?
david
This is very complicated and I am not a doctor, nor do I study this for a living. Here is a except from a study about SARS which, from what I have read, has many similar characteristics to COVID-19.
The dried virus on smooth surfaces retained its viability for over 5 days at temperatures of 22–25°C and relative humidity of 40–50%, that is, typical air-conditioned environments. However, virus viability was rapidly lost (>3 log10) at higher temperatures and higher relative humidity (e.g., 38°C, and relative humidity of >95%). The better stability of SARS coronavirus at low temperature and low humidity environment may facilitate its transmission in community in subtropical area (such as Hong Kong) during the spring and in air-conditioned environments. It may also explain why some Asian countries in tropical area (such as Malaysia, Indonesia or Thailand) with high temperature and high relative humidity environment did not have major community outbreaks of SARS.
Some of this is affected by indoor vs. outdoor transmission since in some warm and humid places people tend to spend more time in air conditioned areas which have lower relative humidity.
Again, I will leave it up to the experts to figure this out.
The Australian CSIRO (our peak science org) announced today that it has developed two Covid vaccines and is under way trialling them. Would still be a year away from a release if they are proven but every potential is one more shot at finding a pathway out of this situation.
I’m unsure (and unsure is the default for all things in these times) but I also feel that we must follow due process.That is more good news. Is it possible that if the fatality figures continue to climb exponentially, at some point, perhaps 1M dead in US or more globally, the vaccine release date may be moved forward from mounting pressure to stop the deaths, despite incomplete trials and testing? I sure hope it never reaches that point.
other OTC drugs which might be helpful boosting the immune system are
Quercetin 500mg 2x daily
Luteolin 50mg 2x daily
But Zinc seems to be very helpful
Thank you Steve. I bought some Quercetin today.
It's advice and information like that which makes this thread so valuable.
Keep up the good work
Apart from mask which 93% of Thais are using (we also donate all N95 to hospitals and mostly use non-N95), alcohol gel should be in every shop cash register. It is not only to kill virus but seeing people using it induce habit of getting hands clean. Knee jerk habit actually saves the paranoid.This is an interesting story about a town in Tuscanny with the largest Chinese population in Italy and correspondingly lower infection rates due to their cultural behaviour of wearing masks and self isolating early on before there was a nation wide lockdown.
https://www.scmp.com/news/world/uni...onavirus-why-prato-home-italys-biggest-single
