What do you think of this video. And this is not directed to those who think every mobile phone video is trash, thanks. Please listen to the end for the brass and the woodwinds
Would say is even more synthetic.
Hi Hieukm,@Tango @Audiophile Bill @the sound of Tao Please tell you what you think about the same recording of track "Tango"? Do you think it has the same synthetic trait as WB system?
Thank you for your always great insight. Here is the WB with 2 more bass trap at the back. Now the intergration and sound is even more seemless.Hi Hieukm,
Tbo I am not sure if I understand the term "plasticky" the same way other people said it. On the WB Tango video, I did not pay much attention to tone because I took for granted that it was playing digital. Only when people mentioned it sounded plasticky that I went back and paid attention to it. Then I mentioned the word "synthetic" because I was unsure of the term plasticky. Anyway I think the tone of YG Tango in all instrument not only violin has not enough texture, too slippery smooth, almost glass coated-like and in a sense more synthetic. Where as I actually had no issue with the tone of WB Tango because the degree of glass-coating is not significant enough to distract me. Other positive factors over-shadowed it. That system surprised me.
This video instruments are more articulate but it comes at the expense of recording ambient which presented more in the light out video. The additional bass traps seem to clean out ambient info and lost the charm. Listen and compare from 1:06 of both videos. You will hear better than I explain. If I were the owner I would stick the additional two tampons up Ked's arse.Thank you for your always great insight. Here is the WB with 2 more bass trap at the back. Now the intergration and sound is even more seemless.
This system resolution is off the chart due to the expensive cabling. His cables should retail around your speakers or more.
Speaker cable currently is Nordost Odin 2Those speakers in that room though!
What are the speaker cables?
Cable that cost more than my speakers makes my head hurt.
This sounds considerably better to me than the YG setup. Much more harmonic complexity on the violin and overall fullness of the orchestra.
I would recommend the owner to include some diffusion in his room and remove the last couple of traps as it has gone a tad dry for my taste.
I would think the brick walls help matters. I suspect typical drywall sheet rock would be much worse.
Those tube traps seem a middle size in diameter so I wonder what frequencies they are designed to attenuate in the corners. I am also curious about whether or not there has been experimentation with rotation of the reflection strip on the tube traps.
My ex could play this piece quite well...she was more amazing the more technical the piece got. Romantic pieces she was perfect but lacking a bit of "soul".
Previously piega in the WB room used to boom much more.
I tried to find the video on his channel but couldn't, but this one is good. I think that Piega is a good speaker based on this though needs a buffer one
Yes I have brick and concrete walls that help considerably as well as very high and sloping ceilings.
Brad - you could make use of that roof by coupling a bass horn to it
