Taiko Audio Daiza platforms.
Reactions: Taiko Audio
every piece of gear in my signal path uses the footers shown below (with the copper plate removed) between the gear chassis and the Daiza with the open end with the foam insert facing down. it does take a couple of days for the foam to adjust and be optimal. Emile can explain the process more.
Hi Mike,
Just curious;
Are the special feet on the Extreme with the incorporated Panzerholz not sufficient to properly couple it to the Daiza platform?
@Rhapsody;
Hi Bob,
Do you couple your Extreme to the Daiza with separate Panzerholz feet as well?
Hi Mike,
Just curious;
i'm trying to recall whether i personally did a comparison of the small round foam filled panzerholtz footers to the special feet that come with the Extreme, or whether i just asked Emile which way i should go. i think Emile said the latter, and don't think i listened/compared myself.
it also might have to do with the fact that all the boxes my 3 chassis MSB Select II dac are on double Daiza's with those footers, the whole synergy thing going on with the digital signal path (the whole greater than the parts). not saying that is exactly it, but i suspect it is.
sorry i cannot give you are more definitive answer. maybe Emile will chime in.
Reactions: heebrog
Hi Mike,
Just curious;
@Rhapsody;
Hi Bob,
Hi heebrog,
I use CMS Center Stage 1.5's under the Extreme, then two each Diazo platforms (double decker). I have not experimented after setting this set up together. No need to make it sound any better at this point.
:rolleyes: :rolleyes: :rolleyes:
until you hear better and your reference gets blown up. then your perspective is altered and your mind opens. until then we need peace of mind. and a hole in the sand for our head.
i'm always amused when i read that Steve is all done, till he's not.
btw; i feel exactly the same about my digital, that it's entirely good enough. my USB card should arrive tomorrow. then it will be better, and good enough.
we are definitely in 'good enough' territory.
Hi Mike, I am just referring to the CMS CS 1.5s and the dual Diazo platforms. They have all been there now for two years and honestly I don't see changing those out. Better to focus on other areas for sonic improvements.
Of course if there is an entire new vibration control technology emerges, although I have no interest in active etc, then who knows.
i get it about the resonance, and you may be 100% right about that part. even though i've not personally used the Center Stage, i have tons of respect for it. i'm sure it's different from active. i'm not currently using a active directly with my digital source signal path.
i was just expanding on your comment......and the 'who knows' direction.
Reactions: Rhapsody
I'm waiting for Emile/company to pull the next trick out of the hat:) So far it seems they are on the path with the biggest pay offs in audio signal noise reduction, which I believe is the key to unleashing "the music".
Reactions: Mike Lavigne
Hi heebrog,
Hi Bob. Do you mean that you have two DAIZA platforms, one on top of the other and on the last one the Center Stage 1.5?
  • Wow
Reactions: howiebrou
Ok. Thanks
Reactions: Rhapsody
Keep laughing MIke . You’re the proverbial poster boy IMO. Until youve heard 1.5’s under your Extreme IMO it’s your loss
And yes I’m done Mike. The only thing I’ve done is to add the JL Sounds USB board and finally the Taiko USB board. I guess I always chuckle when you espouse your way is better than all others. Keep on smiling Mike as you’re the King of the Road
you did notice i very specifically posted have the highest respect for Center Stage footers even though i have not had them in my system yet? and i mean that.
all roads lead to Rome Mike.
There are many paths to audio nirvana.
To each our own
I did read it
Did you read mine
It's all good Mike
There are many paths to audio bliss. That was my only point
