@Mike Lavigne Man I wish I was your neighbor. Of course my wife would hate it as I would always be at your place listening to music. Hmm come to think of it my wife might actually like it.......
Muni,sounds crazy...good...thank you for your sound description of the Daiza - got it....do you have any intention to use the center stage footers on the Daizas....
and in spite of all the perfection or because of you seem to enjoy - thats cool - the problem with the end is - it never ends....
Best Muni
Mike thank you again that helps to undermine what I heard from Steve and I will expriment with the footers and a Daiza will come with the Extreme once it is ready to be picked up some time around the end of November - take care...Muni,
i've not had Center Stage footers in my own system. at the last couple of audio shows i attended i did hear Center Stage footers in a few systems and liked what they seemed to do. i also visited Steve Williams's room a few years ago and was impressed by what i heard relative to my previous visit. one big difference was Center Stage Footers.
they are not cheap. from what i hear they may have a bit of a 'signature' in how they influence the sound. i think i like that signature. but would i tire of it? can't say.
maybe the Diaza also has a signature? if so, i've not noticed, and i have 22 Diaza's in my system. it seems very organic and life like.
yes.....it never ends.
Muni, i think it's important to note that most passive resonance products have a signature. which is why we can't throw them at everything blindly. we have to try them and listen. i meant no disrespect to the Center Stage footers. i think highly of them and at some point might try some myself. i view them as one of the best choices and have recommended them many times. i had no intention of undermining anything Steve might have told you.Mike thank you again that helps to undermine what I heard from Steve and I will expriment with the footers and a Daiza will come with the Extreme once it is ready to be picked up some time around the end of November - take care...
Cheers
I have a yes to what you are saying - I will have to check each item of what it does in my system - sometimes others help with describing compared to other items so one can have an idea of wht it would do in ones system - I found almost all the posts here in this forum very helpful in at the end ( never comes ) ordering an Extrem I never heard - guess like quite a few did the same - even if something deosn't have or don't seem to have a resonance pattern - these might make resonances in other parts of the system visible/audible....Muni, i think it's important to note that most passive resonance products have a signature. which is why we can't throw them at everything blindly. we have to try them and listen. i meant no disrespect to the Center Stage footers. i think highly of them and at some point might try some myself. i view them as one of the best choices and have recommended them many times. i had no intention of undermining anything Steve might have told you.
even my active Taiko Tana systems can be said to have a signature. the question is whether that signature is one we like, and whether it gets in the way of the music over time. is it a net gain, and does it endure as a plus.
As an aside……..mike and others are using double Daiza with excellent results. Initially I used CS2 1.0 under my Extreme with remarkably good results but it wasnt until I switched to the 1.5’s under my Extreme that sonically they results are off the chart as they are so good. Perhaps this is analogous to Mikes Double DaizaI have a yes to what you are saying - I will have to check each item of what it does in my system - sometimes others help with describing compared to other items so one can have an idea of wht it would do in ones system - I found almost all the posts here in this forum very helpful in at the end ( never comes ) ordering an Extrem I never heard - guess like quite a few did the same - even if something deosn't have or don't seem to have a resonance pattern - these might make resonances in other parts of the system visible/audible....
I will try both of them and if whichever fits get more...
thank you Mike and Steve for adding your perpective.
Steve, it appears you are saying that Joe advises not to use CMS footers with Daiza platforms because they are "competing" technologies.Mike
You heard the CS2 footers at my house. You haven’t heard the CS2M which IMO is coherent from top to bottom with no sonic signature whatsoever. I even suggested to PeterA that these new footers convey a “ natural” sound There is nothing to undermine. These are different techniques and Joe has always suggested that competing technologies should not be used together. You chose Daiza. I chose Center Stage sitting on CMS racks. To my ears this combination is simply better than anything else I’ve heard
would be great if someone that has both could share his/ her experience...the trouble of break in time of the CMS will probably prevent this from happening....As an aside……..mike and others are using double Daiza with excellent results. Initially I used CS2 1.0 under my Extreme with remarkably good results but it wasnt until I switched to the 1.5’s under my Extreme that sonically they results are off the chart as they are so good. Perhaps this is analogous to Mikes Double Daiza
saying that the Daiza is 'resting' on metal feet is not quite right. more accurate would be there is a small hollow panzerholtz end cap which are the actual footers.Again, the Daiza is: 2” Panzerholz resting on metal feet and with a compliant layer between the feet and the wood. I believe Emile has recommended that whatever goes between the Extreme and Daiza should not be compliant (soft).
My Extreme sits directly on my HRS platform. I have never thought about using footers in addition. Does anyone else have the same configuration with footers? Posting about any experience you have had (good or bad) would be appreciated.
WilSteve, it appears you are saying that Joe advises not to use CMS footers with Daiza platforms because they are "competing" technologies.
I've asked the following question on two other threads: That is,
could you and Joe be more specific as to what qualifies as competing or un-synergistic with the CMS footers? Surely you're not suggesting they are designed to sit only on CMS racks. They have to sit on something. How about a cement floor, or a wood floor? If the Daiza is not appropriate could you explain why?
