Top of the Line Tube Amplifier Companies?
In no particular order....
Thomas Mayer of Vinyl Savior
Nori Komuro of Komuro Amplifier Company and prior works of arts.
Gordon Rankin of Wavelength Audio
Scott Frankland of Scott Frankland Associates - Wavestream Kinetics for when more power is needed than what SET will provide.
Best wishes to all,
Don
Reactions: bonzo75
NAT Audio.
Did you by chance try the Tron Atlantic DAC?
Thanks
Matt
Hi Matt, I have an Atlantic DAC GT in my studio. It's great - very high resolution, lots of nuance, transparency. Very much the "TRON" sound. It has an interesting way of separating pieces of the mix; each part is given space in a way I haven't quite heard other DACs do.
Heads up that I'm a TRON Electric dealer in the USA.
Hello,
Any idea how the Tron compares with the various offerings from LampizatOr?
Thanks much,
Don
Aries Cerat
KR Audio
Ayon Audio
Amplifon
New Audio Frontiers
NAT
WAVAC
Kondo
Air Tight
Allnic
Audiopax
VAC
Viva
Silbatone
Reimyo
Zanden
Absolare
Hello,
Thanks much,
Don
Hi Don,
I used to be a LampizatOr dealer. It's a particularly difficult comparison to make because there is no single "Lampi sound" - you have to consider which tubes are in use as they drastically affect the final sound of the piece. I think the most general comparison I can offer is that TRON gear sounds different. Build quality and fit/finish are substantially different as well.
If you're curious about the Atlantic, DM me and I'm sure we can work out an audition.
Reactions: No Regrets
