Lampizator announcement: launch of our all new TOTL HORIZON DAC
dminches
3,411
2,794
1,410
I just got definitive word from @Lukasz "Lampizator" Fikus via Fred @LampiNA that it is ok to leave the right 2 rear tube sockets empty when using the DAC in single-ended mode.
Reactions: christoph
christoph
4,660
4,058
825
Principality of Liechtenstein
What about the middle tubes "L Neg And Pos" and "R Neg and Pos"?
Are both needed also in SE mode?
Or can one also be left out in SE mode?
dminches
3,411
2,794
1,410
They are both needed.
christoph
4,660
4,058
825
So really only the right two pentodes can be left out in SE mode?
Pity but thanks for your clarificarion.
Reactions: Steve Williams
I wish I could get over my OCD disease because if I could I would take out the right pair of TS KT170 and leave the slots empty but I need to have balance in my life and if I looked at 2 empty slots or two slots on the right filled with different tubes than the slots on the left I would probably have a nervous breakdown trying to resist my temptation to make the right side the same :eek:
Golum
1,806
2,553
405
Lausanne, CH
You saved me some time for typing - thanks :)
dminches
3,411
2,794
1,410
Have someone make up a set of 4 EL34 socket savers and tell them not to wire 2 of them. Use the good ones on the left and the fake ones on the right.
Reactions: rau
Between you
Between you and dminches making recommendations, you have made me fall victim to collecting backup sets so that I can watch those 2 tubes on the right look just as pretty as the ones on the left
Curse the two of you :mad: because I also remember Lukasz saying that even though those two right tubes are not necessary for SE, they burn out at the same rate as those on the left It's like watching money evaporate into electrons
Golum
1,806
2,553
405
Lausanne, CH
Between you
While on that I think You should get a quad of EL51s and EL156s for the starter :cool: :p
John T
1,032
1,607
198
67
Rest assured Steve, you have passed the collecting of backups down the food Chain!
Industry Expert/VIP Donor
Jan 29, 2020
183
1,060
465
58
I just spent half day drooling over the new tube set - the power pentodes called Ei-KT90. They were made in Serbia and sold under Telefunken name. The local brand name was Ei. They are phenomenal. In my Horizon test they beat the GEC Marconi KT66's and match equal the Tung-Sol KT170 (which is blood stained Russian item). If only they werent so expensive. I tried them with VT-99 inputs, French 5687's, and Blue Balls. All were equally good. 1656080826067.png
Golum
1,806
2,553
405
Lausanne, CH
Best of the best - made in Serbia :cool:
Crap - price skyrocketed after this post....lemme trigger my local connections in Nis (city in Serbia where the factory WAS):D
@Lukasz "Lampizator" Fikus - while on those can they be used in TRP?
