HELP - Wilson X! V3 speaker will not play
dbeau
254
209
173
OKC,USA
The left X1 went silent and I've gone through checking/verifying that the problem is in this speaker and not components/wiring by using the other speaker.
My thought is maybe a resistor, but would all drivers be inoperative if it is a resistor. Advice, or experience from Wilson owners w/b very much appreciated.
im betting resistor
Did you reverse the cables to make sure it isn't a cable or your preamp or amp. you know how to trouble soot that by rotating your cables
After you are sure that the problem is not elsewhere can you get a simple electrical multimeter? I would check the DC resistance at the speaker terminals first.
Reactions: christoph
Steve and Micro: Thanks to both. I worked with support at Wilson (Jerron/Trent) who led me through steps.
The problem is not the speakers but a just acquired Pacific Dac and LampNA/Rob is helping me sort out the problem.
I'd like to add that the support level with Rob/LampiNA and Wilson is outstanding.
Hope it all works out well soon!
