Ayon’s output tubes are made by EML…ergo…
do they sound the same?
Little experience with the tube in transformer coupled designs, but I do not consider that the Graaf GM20 was warmish sounding.My understanding is that it is actually not that linear as far as triodes go but the low plate resistance has an advantage in the transformer design...or even no transformer! Most of the implementations I have owned/heard are a bit warmish in character and with balls dynamically.
My Silvaweld OTLs were not as warm sounding as the transformer coupled ones…but this seems to be true for OTL in general. By most accounts though Joule Electra OTLs were richly balanced.Little experience with the tube in transformer coupled designs, but I do not consider that the Graaf GM20 was warmish sounding.
You mean you don’t know?
Joules were very warm - and extremely hot!My Silvaweld OTLs were not as warm sounding as the transformer coupled ones…but this seems to be true for OTL in general. By most accounts though Joule Electra OTLs were richly balanced.
Honestly thought Tri wasn’t around much anymore. They had some buzz 5 years ago.Triode Corp of Japan TRX-M845 Monos 50 Watts Parallel single ended. Will take 211 or 845's though I prefer the 845's. Speakers are Fleetwood Deville supplemented with a pair of Magico Asubs.
No, you made a blanket statement about EML tubes. You have heard Ayon products that use these tubes, no?you brought in 32b and 62b Ayon into a discussion of EML, KR, Elrog, and with the face they are transparent and added the fact they are made by EML. So up to you to say how it is relevant to the point if KR and Elrog are more transparent than EML or not, or if you are just causing data noise, or if you actually either compared to EML in same amp or to KR and Elrog
My Silvaweld OTLs are still to this day the hottest amps I ever owned…and they only had 4 x 6c33c per mono…some Joule amps has much more than that!Joules were very warm - and extremely hot!
I'm confused, is there a debate happening on this topic?you brought in 32b and 62b Ayon into a discussion of EML, KR, Elrog, and with the face they are transparent and added the fact they are made by EML. So up to you to say how it is relevant to the point if KR and Elrog are more transparent than EML or not, or if you are just causing data noise, or if you actually either compared to EML in same amp or to KR and Elrog
Hahahah. Yes, and quite specifically on the same topic of EML vs. competitors.my reply was to morricab, not to Charles, it is a separate strand, keep up.
You are out of luck. This is the problem of "warm tube sound", in our country it is also called "grandmother's radio". This is not a problem of the 6C33C tube, it is a problem of the amplifier designer.Most of the implementations I have owned/heard are a bit warmish in character and with balls dynamically.
This is why I am interested in the listening impressions of @jeffreybehr. EML are simply splendid in my experience, so curious as to his findings.No affiliation, but there's another allnic a-6000 up on usaudiomart for what looks like a decent price. The ad claims the (additional cost) eml-xls tubes are the preferred choice of the designer...
https://www.usaudiomart.com/details...itor-upgrade-10-eml-xls-300b-tubes-available/
I presumed it was already Jeffrey's and we just hadn't gotten the listening impression updates, but it isn't.
Actually I am quite lucky as I have wonderful SET amps to play with...You are out of luck. This is the problem of "warm tube sound", in our country it is also called "grandmother's radio". This is not a problem of the 6C33C tube, it is a problem of the amplifier designer.
SE amplifiers from my photos have incredible dynamics, they easily replace transistor PP amplifiers in a home system.
