WADAX dedicated forum
Amir
856
644
160
45
Tehran, Iran
www.amiraudio.com
Having said that, the Reference Streamer’s musical performance exceeds all the other options I’ve tried – and by a considerable margin. For the first time, the musical quality is more than up to the task of familiarising oneself with new music or making meaningful pre-purchase assessments of new recordings. Trawling through the extensive libraries on Tidal and Qobuz is equally entertaining. As I have already commented, that makes this the first streamer to really deliver on the promise of ‘unlimited musical horizons’ that has been so effectively leveraged by the file replay marketeers – even if that delivery comes at what is for most of u, an impossibly steep price. But that’s not really the point. Like all new technologies and formats, it takes time to achieve really good results. For streaming, that time is finally here and the associated costs are only going to reduce. That’s a big win not just for Wadax, but streaming in general.
I’ve already discussed the comparison of streamed and stored files against optical disc formats, but how does the Wadax Reference Server stack up against vinyl? Once again, that will depend on the record. Reach back into the ‘60s and ‘70s and original pressings still set the standard for natural, credible, audio performance. The only format that challenges that supremacy is the aforementioned and almost unobtainable glass CD. But once we get closer to current pressings, the gap narrows perceptibly, until, close comparison with contemporary digital pressings sees situations in which the file can match or even pull ahead of the record. Back to Ms. Pluhar and Music For A While. The Erato LP is a fine sounding slab of vinyl, one that easily outperforms the already good sounding CD. But compared directly against the 24/88.2 file, it comes up short. The file replay delivers more energy, presence, shape and musical purpose, a more engaging sense of flow and even greater articulation and communication from the vocals. The added body and substance, the vitality and sense of musical direction allow the file to pass the acid test, simply sounding more like real people and real instruments.
Roy Gregory
Reactions: sbo6
Audiocrack
2,187
695
1,158
May I ask what the experiences so far are of all the Wadax Reference server owners / WBF members regarding using the three knobs on the front (output gain, speed and input gain)? They make clearly a significant sonic change for the better if you use them correctly. Are you changing their position every time you start playing a new file or do you choose a certain configuration and let it (more or less) be? I know that with streaming the latter approach works very well but I rarely stream so I am interested in actual experiences with playing files on the hard discs of the reference server.
Steve Vu
195
121
113
I only choose few songs on the hard disc and I tune three knobs based on those songs. After tuning them, I will fix and listen for all.
With streaming, I also do the same.
Audiocrack
2,187
695
1,158
Hello Steve, thanks for your reply. Does this tuning make a significant sonic difference for the better in your set up? And are your listening experiences more or less the same as Roy Gregory’s in his latest review, that is you choose settings around 30% for all the three knobs?
Steve Vu
195
121
113
I chose settings around 50% for three knobs. I think they are the best in my system.
Reactions: Audiocrack
Audiocrack
2,187
695
1,158
Here are Roy’s latest and very interesting comments on the complete Wadax reference combination including the Wadax top of the line DC cables. The outcome of his review differs from what I expected ….
LL21
14,430
2,518
1,448
Interesting...what did you expect?
Audiocrack
2,187
695
1,158
Well, not surprisingly the new top notch PSU for the Wadax Reference server has a great positive impact. However, the Wadax top of the line DC-cables for their reference server and reference dac are exactly the same. The music originates from the server. Under the motto ‘garbage in, garbage out’ I expected that the Wadax Reference server - like their Reference dac - would have greatly or totally benefitted from the new DC-cable. If I understand him correctly to Roy’s ears - and of course based on his listening experiences in his own audio system in his own listening room - that might not be completely the case. Or at least under certain circumstances it might be something of a ‘mixed bag’ with the Reference server while the Wadax top of the line DC-cables are an unlimited casu quo a complete success with the Wadax Reference dac. In combination with the Reference server the standard DC-cable sounds to Roy’s ears - in comparison to the top of the line DC-cable - ”richer, creamier and less incisive”. Do not get me wrong: he is also very clear and explicitly mentioned a few times that the Wadax top of the line DC-cable in combination with their Reference server offers “obvious sonic advantages”. But in an audio system that exhibits an tendency to brightness or with files that suffer from a certain hardness or glare in his view the top of the line DC-cable might be ‘too much of a good thing’. As a consequence he ended his very insightful review with the conclusion that both DC-cables can prove extremely satisfying, albeit in slightly different ways. To me this came as a sort of ‘surprise’.
Kawero
27
70
13
56
I keep it as it is. i only change the knobs when I change to a different speaker or different cable upstrem
Br
Rainer
Kawero
27
70
13
56
I set around 30% but all three knobs are not the same. The effect is most incredible
Audiocrack
2,187
695
1,158
Yep I agree: the effect is really profound. I have only limited experience so far but I also typically prefer settings around 30-35%.
Elliot G.
3,342
3,066
1,910
Fort Lauderdale, Florida
www.bendingwaveusa.com
Elliot G.
3,342
3,066
1,910
Server with Akasa optical wins overall product of the year!
16,220
13,684
2,665
Congratulations, Elliot!
LL21
14,430
2,518
1,448
Fantastic news and congrats to Wadax. Look forward to hearing it at some point in the not too distant future.
