I keep it at 63 balanced from the Gryphon Pandora Line stage. Couldn't ask for better gain match.
I still haven't experimented direct. I like what I hear so much I'm hesitant to play around. Which is a pretty lame excuse!To my ears and in my system 63 was the best as it is passing the entire signal to my preamp which is then used to control the gain. when Lukasz was here in Feb we did the experiment of going direct to amp and I can tell you that using the volume control on the Horizon produced fabulous sound. Several members here in fact are going direct and can attest, I’m sure of this
I would say typically 50%? Morning listening lower. Rarely do I manually change medium bias to high bias on the line stage. I used to use the green bias cable but I'm so familiar now when it would switch to high bias I just manually change it. High bias usually has too much wine involved.Where on the scale are you setting the line stage gain? 25%? 50%? 75%?
I have been direct going back to my Pacific. I have been debating endlessly the need for a Pre but the sound is already damn good going direct to the AC Essentia. My VC listening level is usually 30.To my ears and in my system 63 was the best as it is passing the entire signal to my preamp which is then used to control the gain. when Lukasz was here in Feb we did the experiment of going direct to amp and I can tell you that using the volume control on the Horizon produced fabulous sound. Several members here in fact are going direct and can attest, I’m sure of this
I echoed your comments for a year before I tried it. It was a simple pull the cable out and plug into amp. You should do it for shits and giggles. You may be surprised. I would love to hear your comments if you do.I still haven't experimented direct. I like what I hear so much I'm hesitant to play around. Which is a pretty lame excuse!
Like you if I'm loving what Im hearing, why change, because who could ask for anything better ? Having said that It was worth the comparison for me. Bottom line I think that in the chain of things and if money is a factor I would spend the money on the Horizon and go direct. What I heard at my house was excellent. Like you I still feel that my amp and preamp and phono stage were designed to work best when used together. So for me, old habits die hard.I still haven't experimented direct. I like what I hear so much I'm hesitant to play around. Which is a pretty lame excuse!
Can you please explain?You need a top-quality line stage to maximize the sound quality of the Horizon.
LOL, and my wife lost her mind when I mentioned that I was considering buying the AC Ageto Preamp at $72k.One option I have is to get lower sensitivity speakers. No not kidding. Or buy a $30k preamp as a better attenuator. Unfortunately my wife lost the $400 noise cancelling headphones I bought for her. No I’m not kidding.
But Heisenbergs into Sonja 2.2’i’s sounds like a lovely solution.
you and i attended the launch of the horizon at steves place. We both, I think auditioned the Horizon with preamp and without. At least Idid. To my ears the Horizon was "fine" without a line stage. It was better with it. On a smaller scale I have the ability to vary the output level of my dac or put it in fixed mode. While "volume" will increase when i increase the output level it is not the same as increasing the volume control of the amplifier. Things sound best when I select the optimum output level for the dac then use the volume control to vary loudness.Can you please explain?
This is purely conjecture as I have never ran the H direct. BUT I have run many other DACS direct. Typically it starts off as "I can't believe what I have been missing" then it becomes edgy and fatiguing. It's a big trade off. Not constantly but passages of music don't take on the same tonality. The line stage/preamp adds a refinement that is difficult to duplicate. I wish it wasn't the case. I don't get off spending unnecessary money. Unless its for Tubes!!fwiw, while I was skeptical about going direct from my Horizon to, at the time Simaudio 860a v2 monos, and I was even told by a local dealer to be skeptical, the Horizon direct obviated the need for my prior $36k Simaudio 850p preamp. There was virtually no difference. Clearly my local dealer hadn’t spent time w the Horizon. Then selling the Simaudio amps and preamp and going direct to Audionet Heisenberg monos further uped the SQ.
I must say I am still very curious how the Audionet Stern would change the equation, but for the time being, I am absolutely sold on Lukasz claim that the Horizon offers one of the best linestages out there (I do not listen to any other inputs, so makes it easier).
Further, the gain from the Heisenbergs is less than the 860s, so now at volume 1 on the Horizon, it is very quiet, quiet enough I can leave it playing all day long even while my wife works in the neighboring room. The gain on the 860s was too high.
My sweet spot volume is currently between 40 and 50 on the Horizon, depending on the track, mood etc. (One oddity, which doesn't bother me, is that 47 on the Horizon sounds louder than 48 and 49 until equalized back at 50.)
Very curious to hear from other Horizon owners that are able to do a comparison w a linestage versus direct to amp comparisons. Take good care everyone, great thread, and privileged to be part of this community.
Will,LOL, and my wife lost her mind when I mentioned that I was considering buying the AC Ageto Preamp at $72k.
Remember our deal Greg, if I don't come out of anesthesia. Door is unlocked boxes are on top of the wine room. Help yourself to some bottles. Better bring a big truck!Will,
I recommend the Sony WH-1000XM5 as a gift to your wife first. Make sure she is wearing them, then tell her how much the preamp costs.
Don‘t mean to imply I’m buying Heisenberg and YG. Merely an aspiration.
Still waiting for your deep dive report on the Essentia. Best of luck with your recovery.
John,This is purely conjecture as I have never ran the H direct. BUT I have run many other DACS direct. Typically it starts off as "I can't believe what I have been missing" then it becomes edgy and fatiguing. It's a big trade off. Not constantly but passages of music don't take on the same tonality. The line stage/preamp adds a refinement that is difficult to duplicate. I wish it wasn't the case. I don't get off spending unnecessary money. Unless its for Tubes!!
Perhaps the H will surprise me. I won't be doing it anytime soon with "slice and dice knee replacement Monday" I do have 4 more REL CARBON SPECIALS coming Thursday. I want to see what all the fuss is about over the 6 pack array. Hopefully I'll have enough time to dial them in...Huge room 30' X 26 X 26H with an open loft, approx. 15K cubic feet, with the 9/12 pitch.
We have it in writing now with witnesses, LOL. Can I play with the cables too?Remember our deal Greg, if I don't come out of anesthesia. Door is unlocked boxes are on top of the wine room. Help yourself to some bottles. Better bring a big truck!
P.S.We have it in writing now with witnesses, LOL. Can I play with the cables too?
Most appreciated Greg...P.S.
Send a note next week sometime. Truth is I’d come just for the wine. You are an excellent wine maker, and photographer.
