for those who upgraded to the horizon I am looking for a pair of Kron RK242 anniversary tubes for my Pacific
Pm me if you have a pair to sell
you can post a free "want to buy"ad here.......for those who upgraded to the horizon I am looking for a pair of Kron Kr242 anniversary tubes for my Pacific
Already Have one.I fiqured get a little more exposure here from members that don.t look at the classifieds
Congrats to a loyal Lampi owner. What are you running the H with?It’s not everyday you get home from a long day at the hospital and your six year old son runs up and says “Papa your DAC is finally here! You’re going to be so happy!”
Where he learnt what a DAC is I have no idea. But he was right.
Huge thanks to Fred @LampiNA and to @Lukasz "Lampizator" Fikus for getting this to me before the year is out in my remote corner of Maine. DHL did better than promised and delivered it a day early which is always a crapshoot where I live.
Flight case came well protected with padding at the corners. Getting it up to the listening room was definitely a two person job which I enlisted my wife for.
As expected the internals were immaculately packed;; I was used to the Pacific flight case but the Horizon seems to be better sized and padded, if that’s possible.
Picking the Horizon up out of the case was definitely doable by myself though it was very clearly more weighty than the Pacific. That was quite clear when it bottomed out my floating shelf which floated the Pacific perfectly!
First impression on fit and finish were extremely good; as many have stated, it’s again another step above the Pacific which is itself quite wonderfully engineered.
For perspective this is my 5th Lampizator DAC. I started on this amazing journey with Fred @LampiNA and @Lukasz "Lampizator" Fikus in 2013 with the Big 7, to the Golden Gate, GG2, Pacific and now the Horizon.
It’s certainly amazing to look back and see the evolution and heritage through this line, but there’s always to my ears and preferences a shared sense of ease, flow and emotional connection with every one of the Lampi DACs I’ve owned, all thanks to Fred and Lukasz.
More impressions to come after it’s settled in! Ecstatic to have a Lampi back in place after the departure of the Pacific, which has been sorely missed.
Outboard ps is something I will never do. I test everything and measure everything and came to a conclusion, that psu is best when it is as close as possible to the consumers of the energy. I use supply lines as short as 2 inches and the idea of moving it away 4 feet, adding a cable and 2csockets is just horrifying. There is no noise when everything is properly designed, grounded and shielded. But the dynamics is much better.
Hi @Willgolf ! My setup is pretty pared down/simple. I try to minimize the number of components in the signal path.Congrats to a loyal Lampi owner. What are you running the H with?
Indeed he does. My music room doubles as their movie room, so probably as many hours of Disney are played up there (through the Pacific/Horizon) as I am listening to musicYour six-year-old may not know dacs, but he knows his dad.![]()
I have the REL G2s as well, although I don’t use them much with my Klipsch La Scalas. The La Scalas are a pure horn design, so don’t have not much in the way of low bass under 40 Hz, but their distortion is so low and their efficiency so high that I fear my REL G2s will simply add a layer of high distortion bass sludge to the sound. I need to try them again to see if they can be mated with the La Scalas. I use a variety of SET amplifier. I tried Pass’ First Watt J2, but it doesn’t compare sonically with any of my SETs. I’m still sticking with my Pacific, preferring a single ended triode signal path to pentode config of the Horizon.Hi @Willgolf ! My setup is pretty pared down/simple. I try to minimize the number of components in the signal path.
Right now it's Taiko Extreme -> (FTA Sinope USB) -> Horizon -> Hornshoppe buffered "Truth" volume control -> Pass XA30.8 -> Tannoy Westminster GR/ 2x REL G2.
Working on sonically treating my room, about 1/4 of the way there!
You ain't going to best a good vinyl setup , but the Horizon is about as close as you will get . It won't disappointI have the REL G2s as well, although I don’t use them much with my Klipsch La Scalas. The La Scalas are a pure horn design, so don’t have not much in the way of low bass under 40 Hz, but their distortion is so low and their efficiency so high that I fear my REL G2s will simply add a layer of high distortion bass sludge to the sound. I need to try them again to see if they can be mated with the La Scalas. I use a variety of SET amplifier. I tried Pass’ First Watt J2, but it doesn’t compare sonically with any of my SETs. I’m still sticking with my Pacific, preferring a single ended triode signal path to pentode config of the Horizon.
I do listen to a lot of vinyl, which I can’t seem to give up entirely. Although the Pacific is a lovely DAC, each time I play vinyl with my ARC Ref Phono 3SE preamp, the gulf between analog and digital seems vast. Listening right now to a lovely album with two jazz greats on vinyl. The remastered 24-bit 96 kHZ album on Qobuz is nice indeed, but at least on my setup, not in the same league as pure vinyl replay. It’s like watching a classic film in a theater vs a high quality remastered 4K Blu ray at home. The film is noisier, but the rendition is so superior to 4K Blu ray. Vinyl is noisier, but in my very biased view, somehow gets the gestalt better than the Pacific rendered reproduction. Yes, the Horizon might indeed change my mind, so I’ve been told!
Here’s the album, if you haven’t heard it. A jazz desert island album.
That’s why you should use SEHas anyone played with the volume setting on the Horizon and tried listening at a volume setting under 63 to see how much of a sound quality degradation there is, if any? I am going to do some of this now since the output level via balanced is really high and it causes me to have to turn my line stage to a pretty low level.
I did that experiment and thought going straight through to my preamp sounded best. I also know way back at the beginning of this thread several members were doing the same experiment but IIRC they also were SE and not balanced
Why don’t you go balanced direct to amp as you might prefer itI can listen to either. I have both balanced and SE interconnects going from the Horizon to my line stage. The balanced sounds a little better. The difference is only about 4-5 dB.
To my ears and in my system 63 was the best as it is passing the entire signal to my preamp which is then used to control the gain. when Lukasz was here in Feb we did the experiment of going direct to amp and I can tell you that using the volume control on the Horizon produced fabulous sound. Several members here in fact are going direct and can attest, I’m sure of thisPlus, didn’t you say that playing at 63 (max) produced the best sound?
