The new SFz with 1.5/30 ohms would be near perfect ... the cart has 1.4 ohmsWhich SFz, 1.5/30 ohm or 1/3/40 ohm? How is the synergy between SUT and cartridge?
thanks for the info. 34dB gain might be a little too much for 0.45mV output. I guess a 34-38dB MM phono stage will be a good match.The new SFz with 1.5/30 ohms would be near perfect ... the cart has 1.4 ohms
Kondo Sf-Z 1/3/40 ohmWhich SFz, 1.5/30 ohm or 1/3/40 ohm? How is the synergy between SUT and cartridge?
As the Phasemation EA-2000 Phonostage is far better than the Soulution PhonoPre0.45 mV should match with the Soulution phonostage, why not without the SFz?
this is the KUZMA SAFIR 9 thread, there are Phasemation threads in WBF.Anyone have experience between the Phasemation EA-2000 vs EA-1200 vs EA-550 phonostgaes?
FYI: M. Fremer’s YT video: “Kuzma Safir 9 arm preview review - Full review upcoming in The Absolute Sound”
Perhaps he will do a comparison with the K3 arm.
I don't see the point. He needs 3 or 4 standard set ups now, which are accessible to many, at differing sonic and price levels, for reference. If his compares are going to only be made on a table and arm no one else has heard, it will lose meaning
I was under the impression that the Kuzma SAFIR 9 and the K3 arms are both contenders for the state of the art. Wouldn’t you play those arms on your reference turntable? What turntable do you think Fremer will use to review the Kuzma SAFIR tonearm?
I was not aware that he has three or four other analog set ups for review purposes.
I would 100% miss the 4Point arms removable headshell and fine adjusting the VTA on the fly if I bought the Safir 9 to replace my 4Point 11" which I feel are key and great features of the 4Point arms !FYI: M. Fremer’s YT video: “Kuzma Safir 9 arm review preview - Full review upcoming in The Absolute Sound”
I thought the same thing have loved my 4POINT and so easy to hear and adjust VTA on the fly. But once heard you forget about those concerns and just get immersed in the music. It's like having no tonearm just your favorite cartridge floating on the LP.I would 100% miss the 4Point arms removable headshell and fine adjusting the VTA on the fly if I bought the Safir 9 to replace my 4Point 11" which I feel are key and great features of the 4Point arms !
I was going to say the same thing, small sacrifice to pay for the improvement in performanceI thought the same thing have loved my 4POINT and so easy to hear and adjust VTA on the fly. But once heard you forget about those concerns and just get immersed in the music. It's like having no tonearm just your favorite cartridge floating on the LP.
What Fremer didn't explain is when adjusting VTA on the Safir you must bring the arm back to its holding clamp to to engage the mechanism.
In Fremer's video he has the SAFIR mounted on what looks like a Acoustic Signature turntable. He probably can't mount it on his OMA table because of the oversized platter of the OMA table.I was under the impression that the Kuzma SAFIR 9 and the K3 arms are both contenders for the state of the art. Wouldn’t you play those arms on your reference turntable? What turntable do you think Fremer will use to review the Kuzma SAFIR tonearm?
I guess the challenge is getting the Safir9 set-up to it's peak performance level with a trial adjustment of the VTA off the record that could be multiple times i.e. onto record, listen, if not satisfied with the sound back onto the arms holding clamp, re-adjust etc. numerous times.I thought the same thing have loved my 4POINT and so easy to hear and adjust VTA on the fly. But once heard you forget about those concerns and just get immersed in the music. It's like having no tonearm just your favorite cartridge floating on the LP.
Thank you SOS for your reply. Much appreciated.@Bonesy Jonesy all valid points you raise BUT again I have to state once heard you forget about everything else. The Safir can be adjusted in micro mm and yes it does take a bit extra effort but in the end well worth the trouble IMHO.
