Lampizator Baltic 4
Have had my Baltic 3/4 for awhile now and it just keeps improving - especially after swapping out all the tubes for what Lukasz recommended (listed as front to back):
Emission Labs EML274B
RCA VT99 6F8G with an adaptor to 6SN7
RCA 12BH7
Since swapping in these tubes the tonal density has become so lifelike, the soundstage dimensions so exploded that in the dark it's actually borderline spooky.
And this is in an largely untreated room, can't imagine what it would be like in a dedicated man cave, too bad there isn't a website I could buy one from lol.
Reactions: VoicesInMyHead
RCA 12BH7
Humm... I didn't know about the EML274B,... Which also led me to the Sohoia Electric... Both are reasonable. I might have to try.
Does anyone have a bit of a ground hum on his/her Baltic 4? I am not seeing any ground lug on the Baltic 4.
If yes, how did you ameliorate it?
Thank you.
Has anyone tried the Emission Labs' 5U4G vs their 274B? I'm curious what the advantages / disadvantages are in those two options.
Yes, my thoughts are in the Baltic 3 thread if you search under my user name. The mesh 274b sounded better, top quartile of the @20 rectifiers I have tried.
I decided to try some RCA 12BH7s. It was that or Tung-Sol. I might pull the trigger on a SE 274B.
So it's 11 days.... I spent a bunch of time treating my room and measuring. I've tied speakers close and far from wall. Far feild/near field. Going strictly of measurements, close to the wall was good and it sounded good. Of course now... With as 3D and immersive the B4 is, I revisited all that.
Turns out it wasn't that good. Too toed in, and too close to wall kinda killed the top end. The stage is now even wider, and deeper, and more detail on top. Which fine, that's the room, I just didn't think it could get better. I don't think things have changed much last few days. A non-audiophile friend came over and I gave him a listen... He just giggled the whole time.. In plain disbelief.
I did get the RCA 12BH7s. I want to know what the larger tube does. I'm ever so slightly worried it might be too warm... But I also got the Sophie 274B Mesh plate which is a bit less warm... So we will see what that sounds like. I'm just so floored at how life like and 3D and anything that will supposedly improve that I'm curious about. Other than that, I don't see many more try-out. It's beyond amazing now.
What measurements are you referring to, and what did they show for the first, close-wall position vs the second position moved out from the wall? How did you determine the LP?
I use REW. I didn't measure now, but before. My ceilings are 8ft. My room is basically 16x22... except with 4x10 taken by utility room. It's got a few problems but it is what it is. Listening area is covered with 12-18" of pink fluffy ceiling and walls. Back wall covered in 4" light mineral wool. So during all that tried every which way possible for speaker and sub placement and listening position... All with restrictions of what was possible with the room.
Big picture is upstairs would be better, but I would not be able to listen much. It all works and I'm happy. Downstairs all my reflections are gone. Only have floor left. Got rid of most bass nulls. It sounded good at the time, but now B4 image is so much better. I did some adjusting and improved image. I will probably measure tomorrow to see current setup. I have plenty of absorbtion for mid/upper... I mostly focused on 250 down for best integration with speakers and sub. And all the acoustic folks are like don't discount speakers close to walls with treatment... It did have good bass responce, but now image is much better with speakers about 2.5ft away.
Reactions: cdka
Which of these would you guys recommend most :
---NOS RCA USA 6F8G VT99 MATCHED PAIR Platinum Quality Amplitrex Tested Tubes 1968​
or
---Matched Pair RCA VT99 6F8 6F8G Vacuum Tubes Valves NOS NIB Milspec Gray Glass 6SN7 Substitute With Adapters​
Im also using the RCA 12BH7s "Grey plates" on my Baltic3/4, want to try the RCA 12BH7 Black Plates D-Getter,
Reactions: Ron Resnick
I would look these up on tube museum for specs
I’ve used all but if I recall the vt99 has less gain but this is memory
As for sound the vt99 is warm of neutral
The various versions of the vt99 all sound similar and warm
But do have tube magic
various 6sn7 tubes have large sound changes from warm to neutral
now this was trialed on more then one Lampi dac as well as headphone amps.
sorry they are the same I have some
Of these. I have a few brands and rebrands
but to me 6sn7 are more neutral in some brands. many have done shootouts on 6sn7 tubes to me
Only a handful sound great
Woo audio has some nos for sale
nos I feel
Need to me new nos in boxes after this you need a tester to confirm and even then it’s tough. any new or nos should be broken in slowly and very low volume till it breaks in pings and pongs can be very loud
Thanks Powerman. Interesting approach you've taken. Apart from a dedicated LR, most of us have room anomalies, especially problems with dimensional asymmetry (and aesthetics, of course). I'm curious to learn whether you tried diffusion to supplement/augment the current treatment scheme.
Reactions: Miki70
I just replaced the blue ball tubes with RCA black plate 6SN7 GTs. I have not compared them sonically.
Exactly my experience, but in the Horizon
Generally RCA's do produce a warmer sound. This may work well in some systems.
Either pair of the 6F8G's that you are looking at should work for you.
"VT's" are military rated tubes and have been tested to higher standards that the more common consumer tubes.
I was surprised to see the 6F8G's with a 1968 date as I didn't know that they were still being produced at that late a period of time.
However both the boxes and the orange/red lettering on the tube do indicate later manufacturing.
Between the two, I would choose the grey glass version as they are Milspec "VT" tubes. The others are not "VT" tubes.
IMO I have found that the earlier tubes (in general) seem to have better tone than more recent production NOS tubes.
Things were changing to Solid State and QC in the tube mfg side were starting to slip.
Reactions: Miki70
