You should hear it if you haven’tLiberace, Cher, and Kiss decide to design a turntable….
Yes, something like that. I think the "normal" Kronos Pro LE is an excellent table and I have heard many more rooms where it sounded good with this table than the likes of TechDas or even Kuzma (although their big one is very good too). The direct drive Primary Control is quite good, especially with their Field Coil arm. Let's not forget that 60K for the "small" (it is only small in relation to the Discovery...it's still a pretty big table) Kronos Pro LE is a LOT of money for one piece in a system.I have heard the smaller one many times. I have no idea where to hear the new big Discovery. I don’t know anyone who owns it. The comment is about the bling of the Discovery. There’s nothing else like it. Nothing to do with the sound. I would love to hear it sometime. I do not see any show coverage of the discovery at Munich. I heard that it’s about $250,000. Is that correct?
Seriously?? I love the look
I disagree. You were the first one to order AS 2000, the others did so after that, and you were the first one in your group and on the forum to order the Gryphon Pendragon, which as you said is quite different from other Gryphon speakers. You would have been in touch with mono and stereo and the Singapore owner, but that still qualifies you as early adopter.
WellI thought Ron cared about “What’s best” not what’s priciest.
I have serial number 10 out of 12. Double digits.
These are show demos. Stavros owns the Galder himself.
I did not know that. That is a big endorsement for the Bergmann Galder!
Why - how do you know Stavros' primary interest is not digital?
OMG, you're right, that's possible. But that would be heartbreaking!
Did I ask Stavros about analog versus digital in the interview?
Lotus have the following Pre-Loved listed atm:I think Brinkmann Balance is a great table at a lower price than the expensive ones that even when not better than some expensive ones on X or Y or Z attribute, is a sufficiently good and complete table for the owner to be satisfied and to now focus on records
Brinkmann Balance + 12.1 Tonearm (ex demo, as new) | £14,995 |
Brinkmann RoNt III tube power supply (ex demo, as new) | £3800 |
Thank you for correcting me.
I have been under a lot.of pressure with another group to multi amp with class d like Atmasphere and use a Mini DSP SHD. I do wonder if getting all that metal out of the signal path won't make a large improvement. I am told, people with vinyl prefer the active crossover and do not perceive it as a loss of analog. Just an improvement in overall system playback. I'm very unsure. And I don't like having to purchase 2 more stereo amps to bring it all together.The other thing is the signal path. Analogphiles get that if they had a great analog set up, but a digital crossover, their analog playback will be compromised. So they keep passive crossovers in the interest of purity. However, a step further is that complicated circuitry, crossover, and cabling is the equivalent of a digital crossover in killing analog nuances. Therefore I believe in keeping a simple signal path (e.g. First order crossover, very simple circuit no feedback amps, etc. High sensitivity and impedance matched, all drivers firing in the same direction (preferably only 2 max), time aligned). The simpler the signal path, the less is the delta in tables just by going up on an attribute. It is then more important the analog synergy set up sounds right as compared to doing more on some bass or treble axis, as these things get maxed out very fast in such good systems.
No reason to succumb to peer pressure!
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
