When does the first shipment of routers go out
End of July!
Indeed referring to the local network (link) speed, your internet link speed is unrelated to this.
SFP ports are either 100Mbit OR 1Gb, not both. SFP ports do not support auto negotiation. This is a difference with RJ45 switch ports you’re used to which auto negotiate 10/100/1G and can run on all of those speeds. Again this is not possible with SFP ports where you have to choose if you want 100Mbit or 1Gb ports.
There is a way around it !
SFP ports in Dream Machine pro can be set manually to be 1G or 10G.
Did it and it works excellent .
Am I missing something here? New Taiko Router/Power Distributer. Taiko Router for the audio. My current router (Linksys) for WiFi. Dream Machine Pro???
This is about common curtesy. This is a Taiko thread. One shouldn’t be promoting alternatives to Taiko products in this thread. Seems pretty obvious to me. There is an entire website to do that.
Not a pearl but rather a diamond in the roughIgnore “Dream Machine Pro”![]()
That is not SFP but SFP+.
SFP supports 100Mbit OR 1Gb ethernet
SFP+ supports 1Gb AND 10Gb ethernet
@Taiko Audio Emile any idea of how router connected USB vs NAS compares to internal SSD storage?
Tanks for making it clear.
So there will be no infuence of the home router and home modem whatever it is
to the performance of the Taiko extreme with its Taiko router and Taiko switch ?
I still remember that extreme was going to be „ totally immune” to the network twicks long ago
and now we have Taiko Net card , Taiko switch and Taiko router.
That improved performance so much that there is hard to imagine to play without it Now.
25MHz.What is the master clock frequency of the Taiko router and switch?
Dear Emile, I noticed that the Taiko NIC is using I210 Intel chipset. I also noticed that this chip support IEEE 1558 standard. Am I ask you does that mean your card also support this standard!
This standard is the same as PTPV2 clock stamping awareness
Yes. It’s part of Revanna protocol. I am using taiko card for my Revanna as well. (2 Taiko NIC in my extreme) I reported that it did improve the music presentation. I noted that the network clock jitter was improved. But I now want to see if that’s due to PTPV2 compliant that is supposed to come with i210 chip that is available with standard intel NIC. I next move will be change the Ravenna Hub to a PTPV2 aware one instead of the Cisco than I am currently using
