LampizatOr Horizon - Tube Rolling Paradise
Status
Not open for further replies.
Hi Blake
Yup we talked about this before with laszlo and a few others. Problem is the resistor we use. For that value and the wattage needed they are quite long. We could change it for a lesser resistor but the sound signature would be very very different. To a point that the resistor (and therefore the adaptor) becomes an impediment to the sound rather than a positive contribution to the sound.
The adaptor as it stands atm uses a resistor that costs 25 pounds , you can never compare it to a resistor that costs a few cents.
Resistors as I have explained are an evil in any circuit but a necessary one. Which means the quality and type of the resistor used is paramount. All the small resistors used out there with small adaptors including the one Steve has are wire wound resistors with no damping or shielding. It has very poor inductance and damping qualities. If you compare that with thick film resistors like the pathaudio we use , the differences are quite a bit.
We simply can't compare resistors costing a few cents vs one with is costing 25pounds. And wire wound vs thin film. We have turned the adaptor into a positive contributor to the sound.
And I can confirm it is not the sound of the 2504 here that has made the difference but the adaptor. There was a lot of testing in between and having the 5 to 6 prototypes we have, it was very clear there is an effect on sound with the resistor used.
That’s not entirely true. The adapter I made uses a metal film resistor that is small. It doesn’t match the quality of the pathaudio resistor but it also did cost a couple cents.
Which one did you use David? The pathaudio one is a crossover resistor specced for loudspeaker crossovers and an audio resistor
Worth adding that the one Tibor uses is wirewound. I have seen the photos. Happy to be corrected if wrong:)
Nothing special. A Vishay which is heat resistant.
so you’re saying it’s not the tube we’re hearing but the resistor :rolleyes: I maintain that it is indeed the tube we’re hearing but what this adapter is , is merely a different flavor. I don’t dispute they’re great Ian. It’s just that it is butt ugly and just way too tall for my liking. As for Tibors adapters I have no idea what he uses but in my system the sound is nothing short of spectacular.
Also interestingly. With the vishay resistor is derates quite quickly. Tolerance is to 230 degrees but it derates from 70 degrees
Indeed butt ugly I agree but it does sound good:) and looks can be subjective. For eg i hated my Panamera when i got it but its certainly growing on me. Hard to know without trying Steve. Same as tubes if you didn't try the 6900 ecc32 2504 2004 you won't know they are better?
I stand by my thoughts that the adaptor makes a huge difference to the sound.
I’ve said all along that I agree with everything you say. I bet the sound is indeed terrific I truly can’t get past the looks and I listen in the dark
As for the Panamera I understand however I owned a 928 for years and loved the look just shows that beauty is in the eyes of the beholder
I can paint it black:) or create a wooden sleeve over it but wood can be costly - labour charges in australia are crazy. Might even be able to 3d print a carbon fiber filament sleeve as well if that helps:) The part already has some 3d printed parts in there that i custom designed - wont be hard to add more in there :)
btw i found a few more 2504s in my stash if you need any - should be good. enough for all i hope
Reactions: Steve Williams
It must be my OCD personality Ian.:oops:
Bottom line Ian is I agree that sonically you’re onto something and you make perfect sense I have no disagreement. You’re obviously a smart man. Redesign so that it’s not an eyesore and I would onsider but for me once seen it can’t be unseen. It sit right on the bow of the Horizon and as good as I’m sure it is, it’s like a pimple on the face of a very smart and beautiful woman. Again looks don’t improve sound and I listen in the dark but I hope I’ve made my point. I hope none of the readers here think I’m discounting this on the basis of SQ improvement. I’m not. If you don’t mind the looks it’s priced very fairly IMO. Maybe version 2 Ian will have a redesign to appease nuts like me
Reactions: plasmod3
And BTW to all reading Ian just found a few more G2504 ( I assume Valvo) I would contact Ian real quick because I can bet you that he’ll sell out real quick. A Valvo and his adapter I’m sure would be quite something. So one stop shopping
Thanks matey:) Yup ok let me see what i can do :)Will put the brain cells to work:):)
Status
