Now you have your creative hat on. My thought is if you could come up with something like Harry Potter and the Cloak of Invisibility it would be perfectV2 comes with a Shroud - looks better and doesnt affect the sound. The shroud is placed over the adaptor once tehe adaptor is in place and then you attach the tube to the adaptor. Any thoughts? the white line in the photos is the flash. the unit is all black
yes indeed 1 tube just doesnt get the gainI believe it's necessary to use two C3Gs similar to 6J5s where two of them make up the gain of one 6SN7.
haha there is no knowingNow you have your creative hat on. My thought is if you could come up with something like Harry Potter and the Cloak of Invisibility it would be perfect........Ian check your email
yes indeed 1 tube just doesnt get the gain![]()
Dual tube is good MarkThis is the adapter I used Ian. To be fair to the seller, he did say that I should buy the dual version but I tried to avoid the fugliness. Generally speaking, the dual adapters are used when you replace a dual triode with a single triode (like the 6j5 Etor mentioned) to pass a differential / xlr signal rather than to get more gain. The latter should only be 3db? When I tried the single, I was having to dial in more like 30db less attenuation and it literally did seem like the source was on the other side of the Atlantic.
1pc Gold plated C3G TO 6SN7 Tube adapter For Elise by Feliks Audio or Woo WA5 | eBay
Find many great new & used options and get the best deals for 1pc Gold plated C3G TO 6SN7 Tube adapter For Elise by Feliks Audio or Woo WA5 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
c3g tube has 6 times higher amplification, an optimal working point would be 150v anode/ 20ma current or 200v anode/12ma current then it would be very loud compared to a 6sn7. below that, the distortions will increase sharply. can sound very analog and warm because below 10mA current are then in the kink of the triode characteristic.I believe it's necessary to use two C3Gs similar to 6J5s where two of them make up the gain of one 6SN7.
For those keeping track of these things, my Tak 274b failed today. Purchased 8/22. Used about 80% of the time. FWIW, it sounded great up till the point of failure.
Thanks for bring that up. I am investigating this. Was received 8/20/2022 so well under a year. I’ll report back when I receive a disposition.still under warra
still under warranty? there is a 1 yr replacement warranty but august is not far away best do it quick
My new Tak 274b failed after 3 months of use last year. According to the distributor, i was supposedly the first field failure they had. Fortunately, it was replaced under warranty, However, that is one reason I sold the replacement quickly. Failure of a 50 year old, $100 tube is understandable. Failure of a $1200 new tube? Not so much.....For those keeping track of these things, my Tak 274b failed today. Purchased 8/22. Used about 80% of the time. FWIW, it sounded great up till the point of failure.
LOL, no real drama. On start up a wisp of white-blue light appeared at the top of the envelope. The pixie tubes did not illuminate, the tube was cold, no sound. Catastrophic meaning abrupt and final, but no other consequences.I'm curious - when it died, how exactly did it fail?
Something about "catastrophic failure" sounds more dramatic than I'd normally expect...
I envision the catastrophic failure something like thisI'm curious - when it died, how exactly did it fail?
Sounds like there was a short at the top of the tubeLOL, no real drama. On start up a wisp of white-blue light appeared at the top of the envelope. The pixie tubes did not illuminate, the tube was cold, no sound. Catastrophic meaning abrupt and final, but no other consequences.
