The Cossor factory is/was 10 minutes walk away from me at Highbury & Islington.https://www.pricemyers.com/projects/london-screen-academy-118
What are you using these Tungar supplies for? I love the look of these.
Direct current for the Lomo tweeterWhat are you using these Tungar supplies for? I love the look of these.
What are you using on the silver?Silver dip for today’s ecc40 as they typically have silver plated pins which the acid would otherwise strip
I saw that. I was wondering if there are better brands than others. I want to clean surfaces, but I don't want to strip the silver. And it needs to be water soluble to rinse clean.Silver dip.
I used an English brand called Goddards but don’t know if that’s available in USA. Silver dip won’t strip the plating and is usually water soluble.I saw that. I was wondering if there are better brands than others. I want to clean surfaces, but I don't want to strip the silver. And it needs to be water soluble to rinse clean.
Thanks
So the Philips e83f in the photo, which had the acid bath, have I believe untreated steel pins (rather than the silver plating of the ecc40) and 65 years of atmospheric exposure has clearly taken its toll. I’m sure they could be polished however it would be a rather fiddly given the small size of novals and time consuming job for 36 pins. I just wanted to quickly remove the oxidisation rather than do a full restoration.If you look at you pins, they are horribly pittled and blistered. Have you ever tried polishing them smooth. You would remove silver plating, but the contact surface would be much better.
