Exactly. I could dub my tape to cylinder.
At that level.of reactivity, the height of the record would impact the tracking force.That's almost certainly true. For some cartridges, a difference of 0.2 or 0.3 gms may not be very signficant sonically. The ZYX Uni II is unfortunately exquisitely sensitive to VTF. The range between mistracking, good sound and bad sound is very low- about 5/100 of a gram! In my current set-up, the ZYX sounds its best at 2.147 gm. My guess is there is considerable variation from cartridge to cartridge so "set it and forget it" may not be advisable for any specific ZYX Uni II.The general rule for this cartridge as described by others is to find the mistracking point, and then add 0.02 gms and see what that brings to the table. I found that to be good guidance.
No, because that would be a coloration (a term I rarely use because I think it is typically used as a subjective personal preference general purpose slur) which homogenizes everything.Are you looking for warmth on every instrument and voice on every recording?
What exactly do you mean by warmth from an amplifier?
Where is the resting place for all the youtube such as the ones Ron was making.
About an hour. He didn't even have to crack open the instruction manual.How long did it take for your set up installer to get the arm up and running?
Marty, how would you characterize the tonal balance of the ZYX UNIverse Premium? Do you think the upper bass to lower midrange area tends to be full or lean?That's almost certainly true. For some cartridges, a difference of 0.2 or 0.3 gms may not be very signficant sonically. The ZYX Uni II is unfortunately exquisitely sensitive to VTF. The range between mistracking, good sound and bad sound is very low- about 5/100 of a gram! In my current set-up, the ZYX sounds its best at 2.147 gm. My guess is there is considerable variation from cartridge to cartridge so "set it and forget it" may not be advisable for any specific ZYX Uni II.The general rule for this cartridge as described by others is to find the mistracking point, and then add 0.02 gms and see what that brings to the table. I found that to be good guidance.
I agree with this.more like that he has accepted his new purchase and doesn’t know better.
For example, Lamm on the slightly warm side of neutral. This is how Lamm electronics tame Wilson Audio metal dome tweeters and beryllium compression drivers.
the last thing on their minds is that what they are experiencing is somehow compromised
This interesting point brings up psychological issues which I am unqualified to address. I think some audiophiles are more introspective and intellectually honest than others.
I think some audiophiles use whatever decision process they adopt to arrive at a purchase decision, and then, therafter, suppress introspective analysis, cognitive dissonance, and self-doubt to convince themselves they bought the best component in the world. Such a person would think there are no possible sonic compromises with the component purchased.
Applicable to each of us is the ubiquitous problem in this hobby that we don't know what we don't know -- until we hear it. The purchaser of a component may convince himself/herself that it is the best-sounding component possible with no compromise -- that it sounds perfect to him/her.
Based on the auditioning experience of such person it may very well be the case -- to him/her. It may very well be the best sounding component without compromise he/she has ever heard.
But that raises the question of the depth and breadth of the person's auditioning experience -- how many actual and methodologically valid data points are in that person's database? Has the person in question auditioned three amplifiers or 30 amplifiers?
Why did you find the HE-805 fabulous?The only one I have heard is the WAVAC HE-805, which was fabulous but I don't know how that translates to the 833 output tube
It ALWAYS does. JR Boisclair mentions this every chance he gets.At that level.of reactivity, the height of the record would impact the tracking force.
Unless warmth needs to be added deliberately to a system to offset coolness from other components, resulting in a net neutral (non-homogenizing) tonal balance.
I conceive of a spectrum with "cool" at one end (as typified by Boulder electronics) and warm at the other end (as typified by Shindo electronics and early Conrad-Johnson). All electronics fall somewhere on this spectrum.
For example, Lamm is on the slightly warm side of neutral. This is how Lamm electronics tame Wilson Audio metal dome tweeters and edgy beryllium compression drivers in some horns.
Slightly warm. But we are glossing over an issue which is that tonal balance warmth or coolness is an independent variable from -- is not the same thing as -- weight and density in the upper bass to lower midrange regionThat’s interesting. The only time I heard Wilson audio metal dome tweeters being tamed was by Pass Class A amps that were much warmer than my Lamm electronics in my system.
Where on that spectrum of warmth do you want your amplifiers to fall?
Are you saying your tube VTL amplifiers don’t provide the warmth you are looking for?
Finally, which Lamm are you describing
and do you think the Lamm ML2 is warmer than your Jadis?
Concluding that a specific amplifier and speaker pairing do not involve trade-offs or compromises in terms of ability for the amp to drive the speaker or in terms of sonic quality heard by the listener is not the same as concluding that the pairing produces perfect sound. I would agree with those who say no component or system is perfect if that to which it is compared is live unamplified music.
Okay, but I think this is a false dichotomy. Obviously no component or system is "perfect" if the definition of "perfect" is "compared to or indistinguishable from live, unamplified music."
