Good morning WBF!​
Hmm - so the ‘bare‘ Olympus will have USB and ‘XDMI using AES/EBU’ outputs? But AES/EBU has been referred to as constrained legacy technology - does that fact that it is supplied by XDMI mean that its constraints are supervened? And what would the physical connection be between the Olympus I/O and a Lampi DAC? Or did I miss this detail? It is good that you shared news, but it seems that waiting until a more comprehensive set of documentation and pricing is available may enabled greater clarity and headed off many questions (thereby creating less work here for you too!).
XDMI is much more then just the interface to the DAC, it's a combination of software and hardware, AES/EBU does indeed limit it's ultimate potential but it can still take advantage of everything which happens before.
Reactions: oldmustang
Congratulations Team @Taiko Audio for continuing to innovate and push the boundaries!
It does seem like a ‘new medium’, based on the way you have described it, which is really interesting. I’m very happy with my Extreme/Switch/Network card and I’m sure my upcoming Router and NSM will be even better, so I don’t think I will be climbing Mt Olympus; but it is great to see innovation nevertheless.
ReplyIng to my own post: thinking about it further - I can see the desire to keep BOTH the Extreme and Olympus, since, as Emil, described - the Olympus is in a separate category other than digital or analog. Perhaps that means for certain content, the Extreme will be preferable, at least to some ears in some systems.
Also if Extreme has a sonically „better„ CPU than Olympus is it a wise idea to reuse it in Olympus + ?
Or you simply decided to use in Olympus technologies that use specific architecture of a newer CPUs ?
XDMI can absolutely take advantage of more modern / faster hardware, it's up to 2000 times faster then USB depending on which section you're looking at. It makes much more sense to move to an Olympus if you plan on moving to XDMI then if you're sticking to USB. With USB you're about maxed out with an Extreme + Olympus I/O. I would mainly consider an Olympus in that scenario if you prefer to have a single box solution.
There is no power connection between the Extreme and Olympus I/O. When adding he Olympus I/O you replace the USB and Network cards in the Extreme with our QFSP interface cards. The USB and network cards move to the Olympus I/O.
I see. So the battery power in the I/O is powering the cards, not the server. Thanks.
Does that limitation still not apply to totaldac's implementation of aes/ebu?
I may be getting lost here. Is there still an xdmi card (formerly tacdd) option for the extreme or is xdmi only available for Olympus and Olympus io?
Reactions: MarcelNL
Here's an attempt at making the Olympus I/O configuration as clear as possible using photos:
On the left side we have a Switch, then a BPS which powers the Olympus "I" module, this is then connected to our new PCIe interface card by means of a QFSP cable, this card is then plugged into the Extreme replacing the internal network card.
On the right side we have an Olympus "O" module containing the XDMI interface with an analogue output module fitted, this connects to another PCIE interface card by means of another QFSP cable, this card is plugged into the Extreme replacing the USB card:
Olympus "I" module, you can see the QFSP DAC cable being substantially "beefier" then the SFP DAC cable:
And the Olympus "O" module with XDMI interface:
The Interface cards:
so how does XDMI connect to my Horizon? Is it via i2s and if so is there a cable recommendation and a defined maximum cable length
For now that would be over AES/EBU, I2S will follow later, so that would mean you'd be stuck with a 24/192 maximum sample rate limitation for a while.
Would the future connection from XDMI to I2S on Horizon be the most optimal connection method possible or would it be even better if the DAC could have a native XDMI input somehow?
Future applications we're completely open to working on, so is Lukasz, we've been in touch on that already. We have one full time engineer fully dedicated to designing more output options and/or work on integration into other manufacturer DACs. We've also been in touch with Stavros of Aries Cerat and Jonathan of MSB. These 3 we'll be working on first. We've also been in contact with Vincent of Totaldac and agreed that in this case AES/EBU would be the way to go so we don't need to take further action there. In more general terms Dual AES/EBU and various I2S output options are on the agenda.
