Good morning WBF!​
Good point, adding a single color I/O would probably not look that great.
Keep it simple with one solid color as opposed to two (which IMHO gives the odd appearance of two devices)...
I think the solid color looks great the way it is. However, if you have no production delays additionally providing customers with the mixed color options and some want that choice then that's a nice accommodation for Taiko to decide...I'll take my solid silver Olympus asap :cool:
Candy apple red or electric blue metal flake to match one of my amplifiers would be very cool:
Steve Z
Hello Emile,
I am currently working on building a headphone system and was really excited by the possibility of integrating a headphone amp directly inside the Olympus. I wanted to enquire whether there has been any further thought given to this or something that you are actively working on at the moment? I believe it would be a fantastic integrated solution for many headphone lovers.
I look forward to hearing from you.
Thank you!
Hello Emile,
Thank you!
Yes, that is actually something we’re working on in tandem with the volume control option, which would obviously be necessary for that. We actually already have 600 Ohm drive capability but will add lower impedance drive capability, likely down to 75 Ohms.
Reactions: SwissTom
Thank you very much for the update Emile. That is really helpful. The vast majority of high-end electrostatic headphones from manufacturers like STAX, Audeze, HiFiMan, Dan Clark Audio require a 580V DC pro-bias 5pin output. It would be amazing if Olympus could support this connection as I am imagining that most users would like to connect headphones from this cohort to the Olympus.
We’ll look into that! :)
Correct me if I’m wrong, but electrostatic headphones will need a totally different amp than dynamic headphones.
Is Taiko planning on creating an electrostatic amp version of XDMI too?
I'd like to put this following post up for all USA purchasers who are anxiously awaiting delivery of their Olympus , IO orders. International shipments coming into the USA shipped by Taiko come via DHL. DHL serves in the other capacity of clearing the shipment through customs as the official agent. DHL is notoriously slow to clear international orders as the biggest reason is they typically lack the tax ID of the recipient. Usually they post a customs event clearance and they will not reach out to the recipient (even though the online tracking of the package says they will call the recipient). When that happens everything stops until the pertinent Tax ID info is received. When you call DHL customer service to give the information they typically tell you that they don't know what the clearance event was due to and this adds usually 3 days until customer service gets this necessary information and once you give it to DHL customer service, this restarts the progress in the shipment clearance but honestly it's a crap shoot as to when they will get back to clear your shipment and be prepared for this to add a minimum of 3 more days. Once the shipment is cleared through DHL another day will pass until you get another DHL notice stating that you have tax due to DHL for paying the import tax on your behalf. This comes with a notice that says unless they receive payment within 5 days, the shipment willl be returned to sender
As a result I encourage those in the USA who have placed orders with Taiko, to be ready when Taiko reaches out to you to alert you that they will be shipping your order, to have your tax ID (or your social security number) and phone number and email address to give to Taiko as this almost certainly will help avoid delays ( which none of us want)
HTH
Reactions: DW101
I believe that will be best for Emile and Taiko team to address once they have a clear idea which path they want to take. The vast majority of headphone audiophiles are either using electrostatic or planar magnetic headphones. Both technologies have their advantages and drawbacks.
While planar magnetic headphones typically offer more dynamic headroom compared to electrostats, they are low impedance designs – the Susvara from Hifiman has 60ohm impedance while the newest LDC-5 from Audeze is much lower still at 14 ohms. This requires a very low impedance amplifier design like the new dCS Lina for example with output impedance of 0.7ohm to avoid damping issues. The sensitivity also typically ranges somewhere between 92-83db. In my experience, you need a proper high power delivery amplifier to really tap into the full potential of planars. Hifiman built a dedicated amp for the Susvara which weights like 25kg and outputs 20w in Class A to drive them properly.
Electrostats on the other hand have a much higher impedance and also higher sensitivity, typically around 100-105db. Integrating an electrostatic amplifier which can be much smaller and still work really well would hence seem, in my view, like the most prudent solution for the Olympus.
