SRA and Artesenia Audiowhich are the passive platforms you rate apart from Shun Mooks?
can't speak to the Seismion products; but with my Takio Tana systems (which are built around the active Herzan/Table Stable TS series units) that is not what i hear. and not only do i hear increased dynamics and life among other musically positive benefits, i also 'see' a higher peak wattage on my dart 468 readout in the same passages at the same volume setting when engaged (verses not engaged) under my turntable.I heard Seismion platforms under a couple of amps and a turntable. I’m sorry to say that but it sucks the life out the music and reduce dynamics dramatically. If you have a bass and/or midbass thumb because of speakers or room you can be fooled by reduced dynamics but it is impossible to like the sound. Surprisingly when you turn it off it starts to sound better. Of course not as good as any other passive platform. I’m glad that it works for many people. Please listen again.
BTW there can be many think that something is wrong with our trial. No, we tried Seismion platforms the correct way, nothing was wrong, no component, speakers, room, electricity or our ears have problems.
I'm equally surprised by your finding. As I've added Seismion tables under my electronics I've heard increased dynamic articulation, both macro and particularly micro, which brings the music more to life and unravels more of the harmonic fabric of the music. I thought I was gilding the lily to put some underneath the signal chassis of my CH Precision M10's, and I was rather surprised by an important increase in life and clean articulation of all musical threads from that move, too. Quite the opposite impact from what you describe.I heard Seismion platforms under a couple of amps and a turntable. I’m sorry to say that but it sucks the life out the music and reduce dynamics dramatically. If you have a bass and/or midbass thumb because of speakers or room you can be fooled by reduced dynamics but it is impossible to like the sound. Surprisingly when you turn it off it starts to sound better. Of course not as good as any other passive platform. I’m glad that it works for many people. Please listen again.
BTW there can be many question that something went wrong with our trial. No, we tried Seismion platforms the correct way, nothing was wrong, no component, speakers, room, electricity or our ears have problems.
If the Seismion is responding to the vibrations generated by the motor and the rotation of the platter how can it then react to environmentally sourced vibrations reaching the turntable? How can it serve three masters? It seems to me that it’s impossible for the Seismion to simultaneously effectively respond to more than one source at a time.The major vibration of turntable comes from the platter. No platter is 100% dynamically balanced. When it turns, it swings. Active isolator can compensate to a several degree this flutter but not much.
The main function of active isolation with turntable is to reduce environmental vibration from feeding back to the record during play. When music is played, the whole room and equipment rack is vibrating with the sound, this creates a feedback loop back to record surface causing a resonant sound. This reduces resolution. The vibration of motor and platter become secondary.
As I said before, active isolator, like Reactio +/- plus, reduces vibration coming from the rack. This reduction is not 100%, although it is close. Adding extra spikes or cones above and below isolator can further fine tune the sound, but again this is secondary.
I’m glad Tana systems work well with your setup.i also 'see' a higher peak wattage on my dart 468 readout in the same passages at the same volume setting when engaged (verses not engaged) under my turntable.
Did you do those tests simply turning Seismion on and off or do all the hassle of moving it to another passive platform?I'm equally surprised by your finding. As I've added Seismion tables under my electronics I've heard increased dynamic articulation, both macro and particularly micro, which brings the music more to life and unravels more of the harmonic fabric of the music. I thought I was gilding the lily to put some underneath the signal chassis of my CH Precision M10's, and I was rather surprised by an important increase in life and clean articulation of all musical threads from that move, too. Quite the opposite impact from what you describe.
fbhifi, the answer is quite simple:If the Seismion is responding to the vibrations generated by the motor and the rotation of the platter how can it then react to environmentally sourced vibrations reaching the turntable? How can it serve three masters? It seems to me that it’s impossible for the Seismion to simultaneously effectively respond to more than one source at a time.
I am not responding to this thread to just stir the pot, I have a serious interest in active isolation for my Esoteric T1 turntable. To make the equation even more interesting- the T1 has a built in passive suspension.
Heard them many times, both are good but I favor Acapella.Passive base
Acapella fondatio silzenio with Aluminium feets
Finite elemente carbon
Both sounds really good
Finite elemente is so artificial.Passive base
You mean an implementation like this?If the Seismion is responding to the vibrations generated by the motor and the rotation of the platter how can it then react to environmentally sourced vibrations reaching the turntable? How can it serve three masters? It seems to me that it’s impossible for the Seismion to simultaneously effectively respond to more than one source at a time.
you did something wrong, for my the best base i ever heard at homeFinite elemente is so artificial.
You say used the correct way, but give no details on how it was utilized.I heard Seismion platforms under a couple of amps and a turntable. I’m sorry to say that but it sucks the life out the music and reduce dynamics dramatically. If you have a bass and/or midbass thumb because of speakers or room you can be fooled by reduced dynamics but it is impossible to like the sound. Surprisingly when you turn it off it starts to sound better. Of course not as good as any other passive platform. I’m glad that it works for many people. Please listen again.
Sorry I jumped in. Thanks for the explanation but are you sure it’s a good idea to eliminate all the vibrations since sound is a vibration too. What about cartridge? Everyone knows that when you listen close to the cartridge you can hear what’s playing without even turning amps on. Is it good to eliminate all the vibrations on a turntable? How about under speakers?This is a figure that describes the idea of sky-hooked damping. You can consider the dampers to be very strong, and eliminating nearly all vibrations:
Thanks for every opinion! But I’m skeptic. This sounds like the typical topic, that resonances amplify certain frequency regions and avoiding resonances increases resolution and enables even dynamics throughout the frequency range. Both is correct I’d say. I don’t doubt your findings, but I think if amplified resonances lead to better sound, then there’s a need to look for different optimizations at another place first... sucks the life out the music and reduce dynamics dramatically. …
Only the parasitic vibrations from the floor or the motor are eliminated. The vibrations of the cartridge due to the grooves of course remain (the sensors of the active isolation are place inside our top-plate, and not on the cartridge). One could say the isolator removes all "background" noise, and the pure music remains.Sorry I jumped in. Thanks for the explanation but are you sure it’s a good idea to eliminate all the vibrations since sound is a vibration too. What about cartridge? Everyone knows that when you listen close to the cartridge you can hear what’s playing without even turning amps on. Is it good to eliminate all the vibrations on a turntable? How about under speakers?
I’m happy for everyone Seismion worked well under their equipment. I wish it would have been the same for us.
and i'm glad the SRA and Artesenia are working well for you. i did have the SRA Virginia Class platforms (maybe a prototype version) in my system a few years back under my Lamm ML3's. very nice. not owned the Artesenia but respect it.I’m glad Tana systems work well with your setup.
IMHO the right way of testing is not comparing the sound between (active platform that you use) active and turned off. The right way is; comparing equipment over active platform and over other passive platform cause active platforms are not made to be operated passively. But anyway we tried Seismion both active and passive and compared when equipment is over another passive platform (Kondo Kaguras over SRA Ohio and over Seismion).
There are some passive isolators that work well below 4 Hz. For passive isolators, the only way to get isolation in low frequency range is by reducing the stiffness k, because the eigenfrequency equals f0 = 1 / 2pi * sqrt(k/m). Isolation starts at 1.41 times f0.Am I correct that no passive solution works (enough) below 4Hz?
