Some folks have more than one fuse. So in that case in order to get all the fuses in the correct orientation they should reverse each fuse one at a time and listen to the difference, as you intimated arbitrary fuse orientations will have a 50% chance of being in the correct orientation. Audition fuse no. 1 for both directions, then repeat for the remaining fuses, one at a time. Since the first time through, the difference in sound might not be discernible, or barely discernible, pick one direction for now,then move to next fuse. As one proceeds the difference in sound will/should become more obvious. After all fuses have been auditioned once, repeat for all fuses to confirm your choices the first go around. Make sense, now?So I will ask again:
Just think a minute all the leaded parts could have "reversed" leads They are precut to length and binned prior to wiring/manufacturing.
Then you have inductors that can be wound reversed, Then when you install there is no polarity so "right" can be reversed at install.
Let's do a coin toss say 50% are right.
Then you reverse one cord, wire or fuse leaving everything else as is and poof it's fixed!
If your theory is correct how can just changing one while leaving the others alone work?
Makes no sense at all
Rob![]()
This approach works for all (rpt all) fuses, including Bussman and Littelfuse fuses, which sound more open, more airy, more dynamic and “authentic” when they’re in the correct orientation.
