Zayin Audio SupraReg LPS : my favorite LPS in 2024
CKKeung
3,151
3,481
1,910
Hong Kong
I wrote two short reviews on audiophile LPS in WBF sometime before.
They are the best at those moments and I purchased them for my CAS system :
Time flies and they are inevitably surpassed by a newer and even better LPS which is also my current favorite in the market : Zayin Audio SupraReg LPS.
Zayin Audio is a Taiwan brand. The boss/ boss/designer "Funjoe" is in the electronics manufacture industry and Zayin is his hobby.
The exterior design of SupraReg LPS is very diff from LPS of most other audiophile LPS. The front plate is a thick Mahogany plate not only for beauty but also for tuning of the sonics.
There are two versions : 6A & 10A. The latter is for the power-hungry 4+slots NAS.
I auditioned the 6A version on the left in the showroom of the Hong Kong dealer.
Opening the top cover revealed the neatest internal layout I had ever encountered. This is the first prerequisite to good sonic performance.
I don't know what's inside the secretive black box. The dealer said that it's a mains cleaning circuit.
The Zayin Audio SupraReg is designed and made in Taiwan.
All the raw materials & components, even the stainless screws are sourced locally in Taiwan.
It's two dc outputs and the dc cables included in the package are quite unique : the sockets are "female" which is of the higher industrial safety standards.
When I auditioned SupraReg at the dealer showroom, a configuration similar to my home CAS system was employed : wallsocket LAN cable to Zayin Audio Stargate Switch then to Taiko Audio Extreme Switch, the latter was supplied by the SupraReg LPS.
A Plixir Statement LPS was also there for direct comparison.
To cut straight to the point : SupraReg LPS is the best audiophile LPS I have auditioned up till today.
It possesses all the virtues of Plixir Statement LPS and Firebird bird LPS.
The hifi factors (quietness, dynamics, frq extensions... etc) are outstanding yet the musicality has not been sacrificed.
The Best of both Worlds indeed!
My wallet has got another hole again!
It will be used for my Taiko Audio Extreme Switch, closest to my Extreme Server thus giving it the best performance.
My Plixir Statement & Firebird will be moved more upstream, to supply my home router & modem respectively.
Great post, CK! I loved the photos, your helpful description and your clear verdict. You have a knack for being the first to find the best new components in this competitive field. I’ll bet many folks would be happy owning any of the three excellent LPS you reviewed and listed here. In my case though, I have limited shelf space which disqualified the Firebird. As for the two remaining candidates, the neat parts layout of the Suprareg is appealing. Do you think the central metal cooling fins might help screen the circuitry from transformer radiation?
You were unequivocal in your preference for the Zayin Suprareg, but can you imagine other listeners with different musical taste might choose the Plixir Statement instead? In other words, is your preference a matter of sound character or is the Suprareg simply superior in all criteria you considered? Could you clarify where the Suprareg had an advantage over the Plixir?
Yes, the internal heatsink of Suprareg LPS is to act as a metallic shield to isolate the circuit boards from the toroid transformer.
Here is a photo of the interior of Plixir Statement I downloaded from internet.
It's obvious that the internal design & layout of SupraReg is far far better!
Reactions: Opabin
IMHO Suprareg is the LPS to buy.
Only if the system sound is a bit fat or too slow should the Plixir Statement be considered.
Reactions: Opabin
Is there a diference in the sound of the 6A version vs. the 10A version?
I’m interested in the answer to this question, too. The regular 6A version would have enough current capacity for my needs, but would the high current model sound better? Or would the HC version, for instance, sacrifice some of the agility and transparency of the regular version? Has anyone listened to both versions in the same system?
Reactions: CKKeung
Hi Opabin,
You are spot on! ;)
Consider the high current version only if you are considering to use it for NAS which has 4 HD or more.
@CKKeung what DC cable did you use between the Zayin to the Switch? Does the Zayin come with a 5.5/2.5 cable?
The Zain has its own dc cable. Black in colour and quite thick though very flexible.
Funjoe & the HK dealer refused to tell me where it's from.
:rolleyes:
Reactions: keithc
Received today can't wait to try it out
Reactions: MattSPL
I am really curious to try them out and am hoping that there will be a 100v option for Japan usage.
any more reports about the performance and experiences with their products?
Hi @Zappadaddy,
For 6 months, I’ve been using a Zayin Suprareg to power a Taiko DC Distributor (powering a Taiko Router and a Taiko Switch) from one channel and lately a Seismion Isolation platform from the other. It is beautifully made and feels very solid and compact. A direct A/B comparison with my previous LPS, a Farad Super3, was not possible to do fairly because the output terminals on the 2 supplies are different, necessitating different DC cables, but subjectively it seems the Suprareg might have a little smoother, less “HiFi” output. Suprareg may have slightly quieter output as well, but as I mentioned, I haven’t done back-to-back tests. Operation has been flawless. One thing to note: owners must supply footers as the stock Suprareg has none. I tried the Zayin wooden footers but am now using Stack Audio AUVA EQs.
Reactions: Zappadaddy
Bought mine in August 2024 and never used it yet , I'm going to try it on a DJM
ACTIV once I receive it .
  • Wow
Hi @Zappadaddy,
Thanks Opabin. I am also interested about Jcat, Plixir Statement and Ediscreation Firebird. I do not own Taiko, just Pachanko REF
New baby Suprareg.
