Hi thazeldean - my experience also. The gentlemen at Aesthetix worked a lot before they located the errors in my unit, and charged only low hours. Mainly but not only related to the power supplies, which they had to change. No wonder, I think this was partly due to "understandable wear and tear". I had used the control unit for almost fifteen years using it as a preamp, changing volume all the time. Also, I had come into the habit of leaving it on all the time, except on holidays etc, and even if my rack is ok, there is some ventilation, there was also a lot of heat. I think these two factors, over time, contributed to the Io breaking down. I have no direct evidence, just my impression. Cracked soldering in the volume controls created problems in connected components. Not sure, at this point, but I did not experience any clearly tube related breakdowns. Anyway Aesthetix fixed the problems 100 percent.
BTW It is "Io", not "IO". Moon of Jupiter. Part of the Aesthetix Jupiter series. It started "far out" and still is. Sure glad I bought it.
