Some claim a mechanical anchoring of the spindle/platter is better than an air bearing
One of them I believe is Tommy Hørning
That's why you need high air pressure on the axial bearing to absorb lateral forces, e.g. belt tension, so that the spindle doesn't lean against the bearing surface when the platter rotates. I wouldn't build anything with air bearings these days, there are bearings that don't need lubrication anymore, e.g. CMB (Clearaudio) or S Grün from TW Acustic. If a bearing doesn't need lubrication, you can be sure that the friction is very low.
Its ok when it works for you and you are happy with it.The main advantage with a air bearing is the possibility to use a very heavy platter, without much friction. The disadvantages are need of air supply and the potential noise, with some industrial bearings you need very high pressure and very clean air.
Are you waiting for someone to die and leave it to you in his testament ? Very interesting belt setup, what motor does it use ? Love the loose transformer on the floor, better lock up your kids, dogs and cats !Its ok when it works for you and you are happy with it.
there are other good solutions, tungsten carbide bearing max load 600lbs. with 40lbs flywhell 800rpm and 110lbs platter. the best sounding turntable i ever heard in my life. stability in tones is unsurpassed. e.g. piano.View attachment 136296
Next year i get it i hope so.
i enjoy having both in my system. visitors many times have a preference. both ways. of course, there are many variables besides the bearing type too, so it's not any truly scientific compare. but presentation can be right both ways.Some claim a mechanical anchoring of the spindle/platter is better than an air bearing.
No, he gave up the hobby. Sold it to my cousin three years ago. I'm building him a nice tube amplifier in exchange. Revox A77 motor, belt rubberized Kevlar tape. With capstan shafts almost 100% wrap angle on the platter for perfect power transmission.Are you waiting for someone to die and leave it to you in his testament ? Very interesting belt setup, what motor does it use ?
I think after Peter A. emphasized multiple times that there is ZERO physical contact b/w the platter and the plinth that should be sufficient to stop the argument.Thanks for the explanation, but I highly doubt that any turntable uses a full air bearing where the platter is in contact with nothing but an air cushion. I’m almost certain of this because I haven’t seen any concrete proof, just vague explanations from manufacturers that seem evasive. Since full air bearings are industrially available, I don’t believe it’s a patent or company secret issue, but rather a challenge of implementation. I suspect there is a sleeve bearing or something similar to prevent lateral movement caused by the belt, motor, or occasional contact with the platter while changing records. Additionally, there must be some kind of thrust bearing to maintain the air gap between the platter and plinth when placing a record, using a heavy stabilizer, dealing with changes in air pressure, or when the platter is accidentally bumped.
He clearly said that he doesn't know exactly how it is.I think after Peter A. emphasized multiple times that there is ZERO physical contact b/w the platter and the plinth that should be sufficient to stop the argument.
Really?The explanations of the design are “vague and evasive” on purpose, since it’s proprietary and David doesn’t want to divulge it.
This argument, especially my posts are not only about American Sound turntables. It is about the concept of air bearing.And I don’t think he is under any obligations to provide a proof of the concept.
Bollox !!!I think after Peter A. emphasized multiple times that there is ZERO physical contact b/w the platter and the plinth that should be sufficient to stop the argument.
In discussing the issue with David himself, it is my impression of the design as well. Granted I’m not as familiar with the details of it as Peter is.
