I'd be interested to try the Lampi 211 based monos on Interstella. No phase splitter and 85 Watts - should do alright.
Justin, spending a bit more time on WBF after my near-death experience crash landing on my 211.
This thread will become deadly boring soon if I just hog it re tubes/not tubes for the Duettas. So I'm going to ask some different qs over time.
All I can finally say is that there are a whole bunch of spkrs I have actively turned away from considering because they're not IDEALLY suited to SETs (even if they on paper COULD work). Giya G1s, JBL Everests, Rockport Altairs, ML Prodigies etc. With all these, the vast majority of user systems/demos are high power SS, often Class D, w/occasional tubes/SETs. Even Liss'nr uses 200W ch TRL behemoths. If the Apogee was a box spkr w/the exact same specs, I can't imagine anyone here saying go w/tubes, unless we were talking big OTLs , hybrids etc.
So Justin, I don't believe there is any definitive answer to this q, but if I'm to look at the range of systems and user experiences over 3 decades w/Apogees, a certain conclusion seems to be pretty consistent, w/the odd exception.
Hmm, that's more than 10...shall I go on?
I use a McCormack DNA500 on my Duetta Sig's. Yeah, it is probably overkill having 1000-1200 watts into their 3-4 ohm load, but this hobby is all about a bit of overkill, isn't it.
Thanks for the photos! We are at 4.5m/5.5m x 13m x 3.3m but the speaker need to be placed at 4.5m firing down the longer 7.5m length of the room. At 4.5m is when the room goes from 5.5m to 4.5m due to columns/curves. Despite your comments about width, i suspect that it would have to be the Full Ranges. Can they be placed near the wall?
Size comments apply equally for both. There is not much difference between Full Range and Grands, if any at all. Except price. Full Range from Henk can be had at 17k Euro, with Mundorf crossovers. You can then upgrade crossovers over time or go active with more amplification.
The Full range room I heard was 4m wide, but very long. 7.5m would just about be cutting it, and I don't have the experience to say given both rooms I heard them in were longer, so more room for the bass to escape, though in both there was too much space behind the listener.
I didn't get what the 7.5m and 13m - how can both be lengths?
The Room is open plan kitchen and living room and we have curved edges/colums at 4.5m to 'divide' the 2 rooms. The speakers would go there.
