I would love to measure it. But before I trouble you, how much was it?
I already order it. It was $300. It's pricey but I don't mind sending it to you. If I don't like it, I know I won't have any trouble selling it.
Ah, that is pricey compared to AQ. I will PM you with my contact info .I already order it. It was $300. It's pricey but I don't mind sending it to you. If I don't like it, I know I won't have any trouble selling it.
Oh, that is more reasonable. I could buy it or you could send it to me. I just sent you my info. You can decide .My bad: it's $175
I'm not so sure about your interpretation of the waveform, Amir - if the bass was boosted the right side of the waveform should be above the original level when you overlay the graphs. This is not the case from eyeballing the overlaid graphs - instead the graph seems to shows a plot more like a HF filter as per this graph of a 1.59KHz filter from westhostSo the plot thickens . The results of HiFi news measurements runs counter to principles of electronic signals. As I explained in the 44 Khz thread in the science forum, a square wave has infinite bandwidth in theory. That is how it can get its sharp transitions on the edges. Any filtering as such, will reduce the waveform's fidelity, not improve it. Rise time for example should suffer because any filtering will impact the edge, reducing its slope, not increase as was reported in the review measurements.
So being the person that I am , I took the two measurements from the review, changed the color of the one that used the AQ Jitterbug to blue, and overlaid the two in photoshop. Here are the results:
Notice two things that AQ has done:
1. The flat portion of the waveform is now tilted down (left part of it is "tilted up" as I noted on the graph). What causes this? Boosting the low frequencies of a square wave. Here is a great web site on electronics in general, and this topic in the specific. This is the original square wave:http://sound.westhost.com/articles/squarewave.htm
And this is what happens when you boost the low frequencies by 6 db:
As you see the effect very much resembles what AQ has done to our USB pulse train.
It's difficult to evaluate rise/fall times just from these graphs. I reserve analysis of this but, irrespective of eye patterns, a less jittered signal may well result in faster edge rates - I think the analysis jury is still out on this one.2. The rise time is how fast the voltage rises from 10% value to 90%. This is a hard measurement to perform when you have jittery, noisy signals. You either perform a statistical analysis or eyeball it. Using the latter, to my eyes, both waveforms start at the same point at the bottom left, but by the time they get to the top, the AQ waveform on the average is actually lower than doing nothing (in red). The no AQ waveform in red rises to higher value on the average than the blue with AQ.
Seems to me then that the rise time was better without this device which is what the theory predicts.
Are you sure about this compliance figure? I only know of USB compliance with regard to fastest edge rates allowed to be 100pS & a warning at 300pS but not a maximum value for edge rates (although I'm sure there is one)?It is also odd that Paul says that without AQ, the measured rise time was 22 nanoseconds. The limit for compliance with USB spec is 20 nanoseconds.
Yes, I would concur - more testing needed with more accuracyI have a hard time imagining such a short cable, as generic as it may have been, to have failed compliance. With AQ, Paul says the rise time shortened to 14 nanoseconds. Per above, I don't see how that happened. Nor would the theory predict that this kind of improvement after filtering a square wave (unless there was some improved impedance matching).
My theory is that Paul may have swapped the two values. I expect the cable with no EQ to have the compliant rise time of 14 nanoseconds and the AQ worsened that to 22, not the other way around as reported. This would also agree with the previous review that we discussed where my read was that the AQ made his cable unreliable.
Of course all of this is based on some fuzzy pictures so accuracy is not there. But I wish Paul would have put the cursor markers on the waveform as is customary for such measurements to see what points he had used to compute the 10% and 90%. Paul's work is impeccable in quality so I don't expect him to have made such a mistake. But the data is hard to rationalize otherwise.
Not sure why you say this - these measurements may or may NOT signify the underlying mechanisms but I think it's premature to say they are "immaterial in grand scheme of things"Anyway, as I said, all of this is immaterial in grand scheme of things.
Why is this odd Amir?Amir said:It is also odd that Paul says that without AQ, the measured rise time was 22 nanoseconds. The limit for compliance with USB spec is 20 nanoseconds. I have a hard time imagining such a short cable, as generic as it may have been, to have failed compliance. With AQ, Paul says the rise time shortened to 14 nanoseconds. Per above, I don't see how that happened. Nor would the theory predict that this kind of improvement after filtering a square wave (unless there was some improved impedance matching).
The primary claim being made with the Regen and Jitterbug is that jitter is reduced. I noticed that the Wyrd does claim to improve drop-outs but says nothing at all about lower jitter.
Yes and no, because with the Paul Miller measurement he states deterministic jitter is broadly the same from the eye pattern measurement, but analysing jitter at the end of a DAC with and without the product shows subtle jitter deviation.Thanks for posting the graphs, Amir
Just a question - what do you think an eye pattern shows & how do you interpret it's acceptability "in this context"?
My understanding of these eye patterns - what you are seeing in these graphs is a repeated overlay of the scope trace of the waveform.
If there was no jitter each scope trace would exactly overlay the previous scope trace & the lines on the graph would be very thin
With timing differences (jitter) between the waveforms the overlays make lines appear wider in the graph.
The idea of an eye pattern is that USB compliance has a maximum allowable amount of jitter (jitter budget) which will not cause data errors
The eye pattern graph is a diagrammatic representation of this allowable jitter budget - the idea being that at a certain point of closure of the eye the compliance fails. There is a template to overlay on these eye graphs that can be calculated & allows one to judge if compliance is reached or not
But this is about compliance. Are there any guidelines about changes in this jitter pattern Vs audibility? Can changes in this jitter be written off so non-chalantly as irrelevant to audibility?
Remember also that the eye pattern is not showing the spectrum of the jitter just a feel for the overall level of it
Some further information about rise/fall time compliance in USB from here
"There has always been a problem accurately measuring rise and fall times, especially on high speed devices. The measurement of interest is the edge rate, or slew rate, during the state change time. To help improve accuracy of the measurement, the USB-IF is standardizing on one test fixture for high-speed signal quality.
Aside from the fixturing and probes used to take the measurements, major contributors to the inaccuracies in these measurements are the shape of the edge, noise on the signal and the method of calculating the 10% and 90% points as defined in Sections 7.1.2.1 and 7.1.2.2 of the USB 2.0 Specification.
A waveform with slow corners (see sample eye diagram below) will result in a measured rise time that is slower than the actual edge rate would indicate. Also a small change in the position of the 10% and 90% points due to noise on the signal, etc., can cause a relatively large change in the measured rise time. "
"The relaxed edge rate values of 300ps and 100ps apply for high-speed USB signaling"
As I said before - is eye pattern a good measurement for correlation with audibility? I think someone answered yes & used the JA measurements as evidence but I need to look into this further
The eye pattern doesn't show the rise time so we can't determine that. What it does show to my eye at least is that the eye pattern got worse, not better with AQ:Amir,
the eye pattern results showed how without the Jitterbug the PC+USB cable was on the limits of the USB spec in Paul Miller's measurements.
Yes using noise filters on the USB will 'distort' the eye pattern but can be good and bad, will repost that manufacturer document I linked earlier.Rise time is a measure of the mean transition time of the data on the upward slope of an eye diagram.
The measurement is typically made at the 20 and 80 percent or 10 and 90% levels of the slope.
Ok maybe we are looking at how to interpret rise time from the eye pattern differently (I am basing mine from telecoms).
From his graph, look at the red line as it is rising just before and just beyond the bit period crossover.
Without the Jitterbug you can see that the it takes longer, his scale to fit in the publication does not help much though to see such a subtle difference
Sorry, Orb, I don't understand what part of my post you are responding to? Is it my last statement? If so then I'm not following what you are sayingYes and no, because with the Paul Miller measurement he states deterministic jitter is broadly the same from the eye pattern measurement, but analysing jitter at the end of a DAC with and without the product shows subtle jitter deviation.
Key point though is that he ensured using a DAC that takes in the 5V.
In reality the affect on users is going to be between the two extremes of nothing improved to what happens with a DAC accepting the +5V, and what hardware (the internal design of the PC-laptop or comparable) is the source and its design scope for noise/ground/etc.
So if anyone is looking to test, they really need to think this through very carefully from multiple PC-laptop orientated products, multiple USB cables if one cannot measure eye pattern, and critically multiple DACs where some need the +5V and others at the extreme of galvanic isolation.
Cheers
Orb
USB 2.0 has three speeds. The 20 nanosecond is for Full Speed (FS) mode which Paul is measuring. High-Speed requires 500 picoseconds but that is not the mode he is using/measuring.Are you sure about this compliance figure? I only know of USB compliance with regard to fastest edge rates allowed to be 100pS & a warning at 300pS but not a maximum value for edge rates (although I'm sure there is one)?
Be interesting to check how many DACs are FS or HS and utilising the 5V.OK, I assumed it was HS USB we were talking about - most USB audio devices now operate at HS.
Why did PM test & measure FS USB device & not the more commonly used HS USB - as Orb says the filtering requirements are different for FS Vs HS & surely the Jitterbug is designed for HS use? The operating speed of the Dragonfly isn't FS is it ? Oops, look like it is
This makes the measurements sufficiently non-representative to be of little value & I would suspect outside the use case that the jitterbug was designed for.
