Sorry missed this post.Can you name these Horns ..??
From reports we have and also my own experience, it plays bass just fine. We have a couple of reports suggesting that the bass took the longest during break-in, but far more reports suggest the bass was fine right out of the box. So we're looking for more data on that. My own experience has been that the bass of many class D amps from 10-20 years ago was a weak point. I think this might have occurred because the designer thought they didn't need a power supply that was all that robust, since at idle the amp draws so little power. But the fact is the power supply must support the amp at power so you can't skimp on it.Back to the original thread, how would the bass compare to other A/B Power amps?
Not sure what 'more robust current than an ordinary amp delivers' might mean. Current has a very direct relationship to power; defined by a simple algebraic formula, Power = Voltage x Current. What this means is if the amp can make the power into the load, then it makes sufficient current to do so.Thanks, Ralph, for that info.
I now own the Clarisys Minute speakers. I think... they need more robust current than an ordinary amp delivers. I would definitely be curious as to how your amps would perform with these speakers.
ozzy
Aries Cerat Symphonia, Aurora and Contendo Reference
Living Voice Vox Olympian
Avantgarde Duo XD I heard recently was way more explosive than I remembered AG speakers being.
The bigger Acapella models
Martion Orgon
Horns Universum
Odeon Carnegie
JBL Hartsfield (with tweeters)
JBL Paragon
Classic Audio Reproductions speakers
I use speakers that are 98dB in my system. I really feel that the lack of thermal compression is a boon; as I've gotten older I've really come to the position that there are no good justifications for low efficiency and low impedance; both simply mean that whatever amp driving the speaker has to work harder and all amps regardless of technology make more distortion (audible as reduced detail, a less pleasant midrange and so on). Put another way, if you really want to get the most out of your amplifier investment, this is something to which one should pay attention.
But not the Aries Cerat horns and yet you feel qualified enough o comment about them ?Thanks for the list,
Heard the Classic , JBL’s and the AG Duo and trio , the AG Trio was the only one i cared for ..!
Regards
You might want to read this:Horse and course , BTW very high Efficiency and high sensitivity tend to be unbalanced , its why the search for a holy grail amp to balance them becomes the other journey..
So a SET of choice , for balance , its the same the other way , a large enough SS amp with the necessary current, right amt of class A Bias and feedback for low Z loads and you are off ..!
If done right you will learn that both ways can deliver. Get the choice wrong and you will be ducking under the table from those Horns ..!
Its all in the approach ..!
Enjoy
You keep stating that they are equivalent paths and they are not. You can't overcome inefficiency with power...it theoretically and audibly doesn't work.Horse and course , BTW very high Efficiency and high sensitivity tend to be unbalanced , its why the search for a holy grail amp to balance them becomes the other journey..
Enjoy
” Nothing like a “666” Driver .....“
I was in two minds … Why not elucidate ?I guess my “666” comments went flying high overhead ..!
http://www.atma-sphere.com/en/resources-paradigms-in-amplifier-design.html
When using an SET and a successful speaker with it, you're using Power Paradigm technology. A lot of speakers that have controls on the rear are designed for zero feedback tube amps. I'm lucky because my speakers have exactly that: midrange and tweeter level controls. So they allow me to get the speaker to work with the class Ds as well, which have a very good first Watt. So no worries getting the balance!
Me too, but only the G3....the AG Trio was the only one i cared for ..!
These comments just tell me you don’t know any more about what science is or isn’t than Dr. “I am science” Fauci. You conflate engineering practice with scientific understanding. Science is a methodology that involves conjecture and measurement. I am taking both into account to build a hypothesis based on general observation.Prove it .. !
You seem to always be mixing science with conjecture , maybe i did miss the memo to that jazz /Rock Concert powered by SET amps ..!
Feel free to educate I'm all ears ..!
You have a set up apparently well assembled for this test, as well! Atmasphere and Classic Audio T3.4 comparing the 3.3 OTL SE Edition to the Class D. Will be very interesting to read your conclusions!View attachment 118928
Ok, let’s see what this D class buzz is all about!
