I don't think there is any difference between GE 5-star and regular triple mica, square getter 6072 tubes from the same era, around 1954-1958. They're identical both sound wise and construction wise. I mean General Electric 6072 tubes not the other brands.When you say you don’t think there is any difference between the triple mica and five-star, you mean sound-wise, right?
The URL I attached shows a massive difference in the construction. Differences including five mica in the five-star (paired-mica above and below the plates =4 mica + additional getter shield mica at the top =5 mica) and gold or silver plated grids. It also speaks of holes in the mica, thyratron welding, other including the five-stars being built in a completely separate factory space to all the others GE made.
AFAIK there are only 2 or 3 micas inside small signal double triode tubes. Never heard of 5 mica GE 6072 and I don't think they exist. I can tell you that it's a GE 6072 square getter before 1959 by looking at the inner parts of the tube at the page you shared. Some have support posts and small plates between posts that separate second and third micas as the one in the pictures but it is not consistent through all the GE 6072 tubes.
Specifications, advertisements, brochures may tell a different story but one thing is pretty consistent with GE tubes, especially with 6072s. They are unreliable. It's advertised that they're sturdy, mil-spec tubes and have 10.000 hrs life span but my experience tells the other way. They fail more than any small tube that I ever used. I'm damn sure about it.
1950's GE triple mica 6072 tube means: expect to deal with differences between triodes, be prepared for a tube failure, stock many of them etc. Unfortunately there is no alternative.
