In January, I asked on WBF whether the BACCH-SP--an audiophile product that aims to implement the findings of Prof. Edgar Choueiri--represents the future of high-end audio:
http://www.whatsbestforum.com/showthread.php?16640-BACCH-SP-the-future-of-high-end-audio
Prof. Choueiri is, by all accounts, a music lover, audiophile, and analog enthusiast. His research team at Princeton University has studied how to retrieve fully the three-dimensional spatial information locked within stereo recordings. The way to retrieve this information, the professor claims, is to eliminate the crosstalk that occurs during playback of stereo recordings. Some crosstalk between channels results from the use of stereo miking techniques; this type of crosstalk is desirable for stereo imaging. But unlike crosstalk that results from using stereo miking, the crosstalk that occurs during playback over stereo speakers is additive. That is, when the sound from your right speaker reaches your left ear and vice versa, you're hearing something that wasn't on the recording. The BACCH-SP uses processing of extraordinary sophistication to eliminate the additive crosstalk that occurs during playback. As we all know, however, sophistication doesn't entail effectiveness, so I've been curious about whether the system works.
On a recent visit to Hong Kong, I had the pleasure of meeting, and hearing the systems of, two users of the BACCH-SP. I can confirm that the device does represent the future of high-end audio. I've heard a lot of systems, including supersystems (at shows and elsewhere) and highly revealing studio monitoring systems. The two BACCH-SP systems reveal more of what's on recordings than any other systems that I've heard. Listening to them was also addictive. I did not want to leave either listening room, nor did I want to go back to listening to music without the BACCH-SP.
___
The first system I heard is housed in a carefully treated listening room in the office of Mr. WS Lam's firm MASIS Audio. The system consisted of Sanders electrostatic speakers, Sanders amplifiers, a Velodyne powered sub (no idea what the model was), and pro audio cabling (mostly Mogami, I believe). (The Avantgarde Zeros pictured were on static display.) The source was a Mac-based music server playing files at various resolutions. Mr. Lam's assistant calibrated the BACCH-SP by placing two intraaural microphones in my ears and running test tones as I leaned to the left and to the right. A head tracker connected to the BACCH-SP continuously monitors the position of the listener's head, ensuring that the device's three-dimensional effect can be heard within a sweet spot that is several feet wide. The assistant then demonstrated that the BACCH-SP was working by leaving the microphones in my ears for a moment, playing a song on his smartphone's speaker, walking in a circle around me, and recording the sound through the intraaural microphones. The assistant then played the recording back on the BACCH-SP, and indeed, I could hear the song moving around my head.
Mr. Lam then came in, and started playing music. Using the BACCH-SP, we listened to a variety of commercially available recordings, mostly of classical music. As Mr. Lam explained, binaural recordings result in the most realistic three-dimensional sound reproduction through the BACCH-SP. A number of recent Chesky recordings use the binaural recording technique, and indeed, these recordings sounded startlingly realistic, with sounds seeming to emanate from far beyond the positions of the Sanders speakers.
To my surprise and delight, non-binaural recordings of classical music also sounded remarkable, if slightly less three-dimensional, through the system. We listened to a number of recordings on the EMI, Decca, DG, and Reference Recordings labels. On orchestral recordings, I could clearly hear woodwind sound coming from behind strings, and the string sections seemed to extend laterally far beyond the positions of the Sanders speakers. The relative heights of percussion and brass instruments were clearly audible as well. Chamber music recordings were, if anything, even more impressive, with the scale of chamber ensembles clearly distinguishable from that of orchestras.
The effect of the BACCH-SP in this system was not subtle. Mr. Lam toggled a bypass switch several times, triggering a return to conventional stereo imaging, which sounded both one-dimensional (left-right only) and homogenous by comparison.
This demonstration was extraordinarily impressive and might represent the best stereophonic sound currently possible. I was curious to hear what the BACCH-SP sounded like in a less ideal environment.
___
The second BACCH-SP system was in an audiophile's relatively large Hong Kong apartment. The speakers were models of the audiophile's own design, apparently inspired by the Rockport Arrakis, but using digital crossovers and room correction. Amplifiers were Ncore models, and, again, the source was a Mac-based music server. All the digital gear was slaved to an Antelope master clock. In this system, the BACCH-SP was not calibrated to my ears. We simply started listening to music. I sat in the center sweet spot, and the audiophile owner sat a few feet to my right.
Despite these less ideal conditions, the effect wrought by the BACCH-SP was still obvious. The soundfield extended far beyond the positions of the speakers. The depth of the stereo image exceeded what I've heard through any conventional system. The effect of the BACCH-SP was obvious despite the presence of more than one person in front of the device's head tracker and in the absence of specialized room treatments.
We listened to a few binaural recordings (I believe these were all Chesky recordings but am not certain), and the effect was stunning, with instruments seemingly arrayed in space around the listening position. Conventional recordings of classical music sounded spectacular, too. I've never heard the interpretations of Kleiber, Abbado, and Solti sound so three-dimensional. I thought I knew these recordings, but only the BACCH-SP allowed the spatial information on them to be revealed fully.
I should add that even without the BACCH-SP, this system might have been one of the best I've ever heard. The speakers have extraordinary dynamic capabilities and low-frequency extension. With the BACCH-SP, the system produced a three-dimensional soundfield of greater realism than that generated by any other system I've ever heard, with the exception of the one in Mr. Lam's office.
__
Strangely, the BACCH-SP can be so revealing that it might not solve all problems: it seems that some studio recordings engineered for playback on conventional systems or Apple earbuds probably sound better without it. For recordings made in natural acoustic spaces with stereo miking techniques, however, the BACCH-SP allows the listener to hear information that was previously inaccessible. It's for real.
The technology seems to have attracted a lot of admirers, including David Chesky, and the audiophile press seems to have been wowed by the device at CES. No one's exaggerating how effective the BACCH-SP is. It's revolutionary, and it makes the improvements in playback wrought by a number of other technologies (e.g., DSD playback) seem rather trivial by comparison.
Have I bought one? No, I haven't, but only because I can't responsibly spend $55,000 on audio right now. However, unlike the value of many audiophile products, that of the BACCH-SP seems to me to be indisputable. I hope more serious music listeners can hear it, and I plan to buy one when I can.
___
___
__
