Heh.
So is a dog different from the dogs bollocks (Which, in the UK means the best)
TOTALLY DIFFERENT. let me be clear. The Momentum was AWFUL - a right POS compared to the three others I evaluated.
Heh.
Were you listening mainly to animal sound recordings???![]()
my assumption when we are talking the EMT vs CH P1 is a matter of taste and maybe even more the synergy with his system altogether.
Tube vs SS at their best if we can be a bit extremest for making a point.
Richard will went for the 4 box P1 set up eventually as i gathered, i think he got the P1 for now and a X1 on the way.
i truly understand his stand about it![]()
i wish i will get the chance to do it also.
Hi
can you explain the relevant for the pops and ticks?
thank you!
Yes.
If the preamp has stability problems, it will exacerbate ticks and pops on the LP surface that are otherwise inaudible, bringing them to the front. The instability is very much like ringing, and is usually caused by poor 'stopping' of the input means on whatever devices the preamp uses for gain (if a transistor, the base needs to be 'stopped', if a tube, the grid and if a mosfet, the gate). Please keep in mind this is in a rather small nutshell, but if the gain devices in the preamp are not properly stopped, not only will the preamp make more ticks and pops, but input loading of the cartridge will be mandatory for proper sound and the unit may be prone to RFI problems.
So a clue that you may be hearing more ticks and pops that you should is often that you had to pay attention to loading the cartridge correctly to get it to sound right! IOW, if the sound really does not change with the cartridge loading, you'll probably also hear less ticks and pops, despite having the same or better bandwidth.
FWIW, tube preamps are less prone to this problem than solid state, on account of the fact that it is harder for tubes to rectify RF energy on their grids, while this is quite easy with a transistor or mosfet.
For these prices the phono should also give you a lap dance.
Seems the ones buying the CH P1 are reviewers with probably insane industry accommodation prices.
What happened to the mega priced internet darlings of a couple of years ago? Vitus and Trinity?
thank you! this info is very interesting. i have never thought about it.
I'm very convinced that unstable phono sections such as you see in most Japanese receivers made the 1970s-1980s raised an entire generation of audiophiles that expect ticks and pops on LPs and are thus largely responsible for the development of the CD.
When an LP is produced, part of the process is the artist and engineer have to sign off on the test pressing, which in part is used to determine if there are any surface defects on the project. IOW there really should not be any ticks or pops on the LP when new unless the production signed off on it. Yet many audiophiles went digital because of ticks and pops. Well, turns out a lot of that is just the phono preamp itself.
So whatever the 'best' phono preamp is, a lack of ticks and pops without any loss of 'air' will be one of its signature traits.
i think in the end of the day most of the pops and ticks we heard are coming from electrostatic charge or\and defects on the vinyl from the printing process itself.
Phono preamp stability is one of the least understood issues. BTW, thinking of the FM Acoustics' de-clicker circuit, it might be a trick, in the sense that turning it off de-stabilizes the unit, so the on/off switch is for show
I have heard the de-clicker works. Bottom line, if occasional clicks bother you during LP play, change your format and play a cd/file....lol
Atmaspheres comments are enlightening
i have noticed since i cleaned up the RF on my phono the grooves are much quieter
i don't adjust load any more just use step ups
To my understanding there is a balancing act that must take place in stopping the rectification of rf or cartridge induced high frequency noise that must be managed against the negative effects of cartridge unloading on voltage attenuation. Its not as simple as a phono stage is stable or not. To my understanding the goal for any phono stage (for a given amount of cartridge induction and cable capacitance) is to flirt with stability visa-vis the incumbent rf stopping (mandated by the aforementioned capacitance and induction) so dynamics are maximized visa-vis voltage maximization since phono preamps are generally voltage gain mechanism not current. So stability at the expense of dynamics is not entirely a good thing, ergo the reason manufacturers provide options to stop clicks with switches and loading options.
Comparing two cables, the one with higher capacitance may exacerbate clicks and necessitate the election of lower loading to dampen the clicks (through a switch or otherwise) but this will be at the expense of voltage attenuation in a voltage gain mechanism which on the margin has performance consequences particularly in dynamics. Same with the variation in cartridge induction combine with a given cable capacitance. Phono stages must be flexible devices and certainly it is possible to set one up so its instability is distasteful, but that my be more an indication of the competence of the user than the inadequacy of the stage.
a phono cartridge provides the highest resolution and widest dynamic range when the phono stage load resistance is of as high of a value as possible (10kohm rather than 100ohm). Realistically too high load resistance values will force the phono stage into distress due to insufficiently damped and too-large levels of ultrasonics and frequency peaking [ack: refer to research in post #32], so practical load resistor values need to be a compromise between a value that is low enough to keep out of the phono stage's danger zone, while loading the cartridge as little as possible. The reason why less capacitance in the tonearm cable is an advantage is that doing so allows the use of higher load resistance values at the phono stage input.
